Something wrong with AC/Heat
Old Sep 24, 2006 | 08:37 PM
Stigen's Avatar
Default Something wrong with AC/Heat
Well I have recently got a 93 accord lx and so far it runs great. But the only problem is when I try to run ac or heat I can hear it kick in but nothing blows out of the vents. What makes the problem weirder is at random times the vents will just blow out air when I turn it on. But it does that very rarely and I have no idea what the problem could be? Anyone have any guesses?
Old Sep 24, 2006 | 08:51 PM
02 accord's Avatar
Default Re: Something wrong with AC/Heat (Stigen)
Yep. The problem is an intermittent blower connection. Check the wiring for the blower to see if any connections are loose.
Old Sep 25, 2006 | 11:12 AM
richardtires's Avatar
check the wiring
Old Sep 25, 2006 | 02:20 PM
hondadude's Avatar
Cliff notes: blower motor intermittant??
Do a cave man test and thump the bottom of the blower to see if it starts running.
If that is what happens the blower motor brushes are shot. Motor needs replaced.
If this isn't the real problem you'll have to clarify the problem in your post
Old Sep 26, 2006 | 07:41 AM
cdzant's Avatar
I have a 94 accord and my driver side fan doesn't work and the a/c wont blow cold. I was told that it was a sensor on the bottom of my radiator. Can anyone tell me what it is called or where it is exactly. Thanks
Old Sep 26, 2006 | 07:47 AM
hondadude's Avatar
Default Re: Something wrong with AC/Heat (cdzant)
Hey thread jacker, this thread is about an internal blower fan Not a radiator cooling fan. It's easy for you to 'SEARCH' or start yer own thread
Steve LeB
Honda CR-V & Element
Oct 19, 2016 10:05 PM
Tip14
Jun 17, 2008 01:41 PM
mymeatb18"
Jun 10, 2006 03:11 PM
