B18A1 OBD0 Wiring Harness
Old Sep 24, 2006 | 08:36 PM
SLowCrx's Avatar
Default B18A1 OBD0 Wiring Harness
Im swapping a B16A into a 89 Civic Si. Im gonna be using a B18A1 wiring harness since someone butchered the B16 harness. So my question is what is this plug in the pic circled in red used for ? Can I just cut it off and tape it up if its not needed? Also need to know if im right on these other plugs colors since I have to put new ends on them because they are cut off..
YELLOW w/ RED STRIPE = Oil Pressure Switch on rear of block (Dummy light)
YELLOW w/ GREEN STRIPE = Thermoswitch on rear of Block
SOLID BLACK = Thermoswitch on rear of block
Sorry for the shitty camera phone pics..
Old Sep 24, 2006 | 09:16 PM
SLowCrx's Avatar
Default Re: B18A1 OBD0 Wiring Harness (SLowCrx)
Old Sep 24, 2006 | 10:17 PM
SLowCrx's Avatar
Bump
Old Sep 24, 2006 | 10:25 PM
Rywire's Avatar
u sure that harness is integra... thats a egr plug
Old Sep 24, 2006 | 10:32 PM
SLowCrx's Avatar
Default Re: B18A1 OBD0 Wiring Harness (droppedcrxsi)
Yeh I forgot it is from an auto Teg... Should this harness still work?
Old Sep 24, 2006 | 10:34 PM
Rywire's Avatar
no, you cant use a teg harness on a ef...
Old Sep 24, 2006 | 10:37 PM
SLowCrx's Avatar
Dont tell me that.... I can use the Si harness right? What is the difference in the teg harness other than the EGR plug? They are both OBD0 the harness is off a b18a1 OBD0 engine..
Old Sep 24, 2006 | 10:56 PM
sanimalp's Avatar
$cat /dev/urandom
you just need to use the si harness. everything is plug and play except the wiring for vtec. the integra harness and the b16 harness both will not work.
Old Sep 24, 2006 | 11:17 PM
Rywire's Avatar
Default Re: B18A1 OBD0 Wiring Harness (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote"> the integra harness and the b16 harness both will not work. </TD></TR></TABLE>
CTR_B
Jun 18, 2008 04:25 PM
Sickteg24
Jan 18, 2008 12:51 PM
NINETY2CIVIC
Oct 24, 2007 02:58 PM
Sean @ ESG
Feb 23, 2006 01:30 PM
Charlie Moua
Feb 27, 2002 06:11 PM
