Car didn't start... no crank when turned over
hey, this is the second time this has happend, first it was back in feb.
i put the keys in the ignition and turn it to ON. I turn to START but the car won't crank. I have power as the windows and all my lights work but the car just won't crank. Several attempts, i decide to hold the gas pedal down. and finally it cranked and started.
What is the problem? fuel pump? (this happened before in feb and i held the gas pedal down and it worked)
aww. just search that stuff and seems difficult to do. im thinking about just leaving it.
whats the worse that can happen? (car didn't start for like 15 minutes back in feb, was stuck in the hot heat at school
this time it was for like 5 minutes)
check your dizzy i had a problem similar i wasnt getting spark. you should be able to hear your fuel pump turn on it is a high pitch whine fallowed by it clicking off
btw dizzy is a 30 min job at the most 7 bolts/screws
blaxican05
Feb 23, 2008 08:47 PM
si0385.
Jan 13, 2006 03:31 PM
Tad
Jan 3, 2006 06:37 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
