What Cams are you using if you have Nitrous in you car?
Old Apr 30, 2002 | 11:42 PM
Midwestrider's Avatar
Default What Cams are you using if you have Nitrous in you car?
What cams are you running in your setup with nitrous? My D16 will be coming out soon.. Going in will be a GSR (after built)
The motor B18C1.
Nitrous setup-wet setup 75 shot (single fogger), or 125-150 (direct port)
C/R will be 11:1 or 11.5:1
Block will be resleveed to 84.5 etc..
Head will be mild p/p etc..
The cams I am looking at possible are
Skunk Stage 1's
JUN 2's
Toda A's
or CTR cams..
I have all the need fuel/ignition mods- MSD Digital 6, fuel pump, fuel filter-currently from my setup on my D16.
Cap, coil, wires, fpr, fuel rail, and injectors will be purchased for the B18c1.
I also have Hondata for tuning, and also a J&S safeguard.
So to the people here with nitrous what are you suggestions on cams to be used?
Thx
Old May 1, 2002 | 12:04 AM
dubster99's Avatar
Default Re: What Cams are you using if you have Nitrous in you car? (Midwestrider)
Anyone of those cams is a good choice
Old May 1, 2002 | 08:36 AM
Slick GS-R's Avatar
Default Re: What Cams are you using if you have Nitrous in you car? (dubster99)
crower makes a turbo/nitrous cam thats is designed for the application.........
Old May 1, 2002 | 09:03 AM
What you run personally?
Old May 1, 2002 | 09:13 AM
Slick GS-R's Avatar
i am running stockers but i will most likely invest in these once the turbo goes in this summer.......
Old May 1, 2002 | 09:22 AM
neo1z's Avatar
Default Re: What Cams are you using if you have Nitrous in you car? (Slick_GS-R)
first of all , on a gsr motor get the plate kit from nos. next, any of those cams are good, im doing ctr cams with my plate kit when i get it. later.
-rob
Old May 1, 2002 | 09:33 AM
Slick GS-R's Avatar
Default Re: What Cams are you using if you have Nitrous in you car? (neo1z)
BTW: i have the nos plate system for sale if anybody want it...............drop me an email if interested
Old May 1, 2002 | 09:37 AM
PM-Performance's Avatar
hey slick gsr. . . nice #'s man .
thats pretty impressive
Old May 1, 2002 | 09:41 AM
Slick GS-R's Avatar
Default Re: What Cams are you using if you have Nitrous in you car? (itr206)
thanks man
Old May 1, 2002 | 10:19 PM
i am thinking on the Toda A's
NirVTEC
Feb 28, 2006 10:22 PM
F120man
Oct 31, 2002 05:25 PM
Midwestrider
May 1, 2002 07:07 PM
Midwestrider
May 1, 2002 09:28 AM
