PCT Pistons On B18A1, What Cams Shuold I Use?
Hi, I'm new to this board but for months has been the place to go whenever I needed vital info for my projects.
For the past months I've been working on a project that consist on the following:
B18A1 Block
B18A1 Head (Ported & Polished w/ Crower Dual Valve Springs)
B16B Pistons
Block Guard
B18C5 Oil Pump
B&M Fuel Regulator
Walbro High Pressure Fuel Pump
4-2-1 Header
Short Air Intake
MSD SCI Ignition Module
And some other things that I can't remember right now...
Now I gotta drop some cams and adjustable sprockets but with those pistons stickin out that much I don't know what cams to use. Thinking about Crower Stage1 but not sure. Please HELP Me. Thanks.
B18A1 Block
B16B Pistons
Block Guard
B18C5 Oil Pump
B&M Fuel Regulator
4-2-1 Header
Short Air Intake
i ran the 403's in mine when i had all motor ls... with the ctr pistons... running strong and i never ran into any problems.. but this is up to you..
WHY NOT RUN A VTEC HEAD? USE A GSR HEAD ON THAT BLOCK RAISE YOUR COMPERSION INTO THE MID 12'S DEPENDS ON MACINE WORK TO HEAD AND BLOCK
Thanks for replying. It's good to know that somebody else did it with no problems.
JDM94EG28: Thanks for the suggestion, but I already have a worked b18a1 head that gives 11.5 cr.
dc2-guy: How strong was it running? Any idea on HP? And, how was your idle?
Thank you guys
Thank you guys
crip
15
Aug 17, 2010 10:05 PM
Allstar
Jan 20, 2003 09:15 AM
