Help me with my problem..
Ok i searched but couldnt find anything related to give me a answer..
I can start my car, and it will run. It drives fine. But as soon as i get on it hard.. say wot till about 5k.. it will suddenly loose POWER and POP ecu CEL .. code is 16, i replaced everything and did a good check. I dont understand, im stumped. It drives fine unless i get on it hard. Not even hitting the redline. Any idea's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Have you ever done a MPFI swap? I had a code 16 with mine. (wire was loose)</TD></TR></TABLE>
neg .. its still DPFI
I removed all the injectors and replaced them with OEM new ones..
Ill check/replace the fuel filter tomorrow! Anyone got some idea's? Its throwing code 4, 6, 14, 16.. I replaced coolant temp sensor (6) and the IACV (14).. which leaves MAP (4) and Fuel Injector System (16)...
bossman032
Dec 16, 2011 11:13 AM
