How to take out the damn Alternator
Old Sep 24, 2006 | 03:27 PM
ef9robert's Avatar
Default How to take out the damn Alternator
I am currently preping my car to swap the motor out. I am following the instructions as given from a online manual that I found. Instructions say to remove the alternator. I was able to remove the damn thing off the block but I am unable to pull the damn thing out of the engine bay. Seems that the brake pump is in the way. Anyone have suggestions on how to remove the alternator?
I have a 90 si hatchback
Thanks.
Old Sep 24, 2006 | 03:32 PM
bboy_mikey's Avatar
i removed my brake pump and it came right out
Old Sep 24, 2006 | 03:36 PM
89 civic si's Avatar
Default Re: How to take out the damn Alternator (teamsonik)
if you are taking the motor out you dont need to take alternator out i just did my swap like 2 days ago if you cant get the alternator out you might need some help doing the swap
Old Sep 24, 2006 | 03:53 PM
TeamRedline89Hatch's Avatar
Default Re: How to take out the damn Alternator (89 civic si)
i just loosened the alternator and pushed it up against the motor, didnt hit anything.
Old Sep 24, 2006 | 04:22 PM
Crx Jimmy's Avatar
if you are taking the motor out why remove the alternator? just drop the motor out the bottom its 10x easier. If you need to get the alternator out for another reason you need to remove it through the bottom, remove the axle on that side and it will drop right out.
Old Sep 24, 2006 | 05:59 PM
IndySporty's Avatar
nah I just drop em roll em to the side and let em rest on something that looks solid until they fall out or stay there forever like mine did! hehehe.....
Old Sep 24, 2006 | 06:26 PM
SF_EF8's Avatar
i removed the master cylinder and it popped right out with some negotiating
Old Sep 24, 2006 | 06:47 PM
24TEN's Avatar
PHANTOM MENACE
I have to ask as others did, if you are swapping the motor out, what's the purpose of removing the alternator? Anyways to answer your question, the master cylinder is in the way. It's a tough one but I had to remove my axle to drop the alternator out. Later I found that if you remove the oil filter, you can reach from under the intake manifold going in from the passenger side of the car and pull it out that way. I should've done it like that but oh well, next time I guess.
Old Sep 24, 2006 | 07:59 PM
Got_soy's Avatar
Default Re: (24TEN)
you can get it yout w/out removing any stuff, i did it when i forgot to put my new one on why i did my swap
Old Sep 24, 2006 | 08:38 PM
ef9robert's Avatar
according to this engine removal guide that i have it says to remove the alternator. Which was a bitch to take the last bottom bolt out, busted out a flat screw driver and a mallet. I will take it out from the bottom using the axel removal technique :-)
Thanks guys,.
Yes i do need help, but no one is available just yet.
Old Sep 24, 2006 | 08:50 PM
sit22 II's Avatar
Default Re: (teamsonik)
just take the alternator braket out ( 2 12mm) and the alternator should fall in yur hands
Old Sep 24, 2006 | 09:11 PM
gsxr1k05's Avatar
Default Re: How to take out the damn Alternator (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">if you are taking the motor out why remove the alternator? just drop the motor out the bottom its 10x easier. If you need to get the alternator out for another reason you need to remove it through the bottom, remove the axle on that side and it will drop right out.</TD></TR></TABLE>
i agree. if your doing a swap whats the point in removing engine accessories??? makes no sense.. hit yourself with a wrench for that one..
Old Sep 24, 2006 | 09:17 PM
ef9robert's Avatar
Default Re: How to take out the damn Alternator (gsxr1k05)
just following the guide i downloaded. oh well. Any good tips on removing the AC compressor and ac lines?
Old Sep 24, 2006 | 09:28 PM
iphatcrxi's Avatar
i took mine out through the bottom
Old Sep 24, 2006 | 09:35 PM
gsxr1k05's Avatar
hey teamsonic, wasnt meaning to sound like a dick.. just too much time in the army heheh. as for the ac lines and compressor, remove the radiator and take em out that way.. itys what i did. no need to remove the bumper like some people will tell you. thats bullshit.
Old Sep 25, 2006 | 07:26 AM
ef9robert's Avatar
Just use some channel locks and take the hard lines off. The lines do not have any freon in them. I want to take the ac cooler off to. By the looks of things i think i need to take the front end off to remove that **** out.
Old Sep 25, 2006 | 08:54 AM
Sequoyah's Avatar
for the alternator, if you already haven't done so...it goes in through the drivers side wheel well. You will have to remove the lower alternator bracket. The position in the picture is where it's ready to go up into position. I don't understand why so many people remove axles, mc's, etc.
Old Sep 25, 2006 | 10:27 AM
ef9robert's Avatar
Okay so remove the lower bracket that is connected to the block right?
Old Sep 25, 2006 | 10:33 AM
xrccrx's Avatar
Default Re: (Sequoyah)
thats what i did, just take your wheel of, i didnt have to do the lower braket though, just took it of and wiggled it out, and the new one back in
Old Sep 25, 2006 | 10:53 AM
wickedEFguy's Avatar
If it's B series I just take out the master cyclinder and it's easy as pie.
If it's D series from what I hear you can slide it under the intake manifold and it cmes out the other side, I've never tried this though....
Old Sep 25, 2006 | 12:01 PM
ef9robert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If it's D series from what I hear you can slide it under the intake manifold and it cmes out the other side, I've never tried this though....</TD></TR></TABLE>
this may work i will let u know.
dont_tri
18
Sep 12, 2007 08:58 PM
fckedhatch
Mar 28, 2007 08:17 PM
Synthead
Jul 31, 2005 08:55 PM
Frito1
Mar 30, 2002 06:24 PM
