I need help ASAP Honda Del Sol tranny..
Old Sep 24, 2006 | 03:14 PM
92hondaswap's Avatar
Default I need help ASAP Honda Del Sol tranny..
can someone tell me if a honda Del Sol manual tranny will fit on my 93 LS 1.8 DOHC engine block??? I need to know ASAP...
Old Sep 24, 2006 | 03:23 PM
TranspeedMotorsports's Avatar
Default Re: I need help ASAP Honda Del Sol tranny.. (92hondaswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondaswap &raquo;</TD></TR><TR><TD CLASS="quote">can someone tell me if a honda Del Sol manual tranny will fit on my 93 LS 1.8 DOHC engine block??? I need to know ASAP...</TD></TR></TABLE>
It depends... is your del sol tranny a B(DOHC) or D(SOHC)
Old Sep 24, 2006 | 03:27 PM
thehatchninja's Avatar
If you have a Del Sol VTEC, then yes.....but it's not going to work in a 93 integra without a conversion kit.
Old Sep 24, 2006 | 04:35 PM
Default Re: (thehatchninja)
Well I was told that if the block on the Honda Del Sol was a B18 series it would work.. I don't have a Del Sol, I have a '93 Acura integra 1.8 DOHC with a cable tranny with hydro conversion, this LS tranny went bad.. I will go tomorrow to check out a Honda Del Sol at a Junk Jard I saw with a Hydro tranny, If the block says B18 I guess I'll take my chances and buy it.. what you guys think???
Old Sep 24, 2006 | 04:43 PM
Eran's Avatar
HT White Ops
Default Re: (92hondaswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondaswap &raquo;</TD></TR><TR><TD CLASS="quote">Well I was told that if the block on the Honda Del Sol was a B18 series it would work.. I don't have a Del Sol, I have a '93 Acura integra 1.8 DOHC with a cable tranny with hydro conversion, this LS tranny went bad.. I will go tomorrow to check out a Honda Del Sol at a Junk Jard I saw with a Hydro tranny, If the block says B18 I guess I'll take my chances and buy it.. what you guys think???</TD></TR></TABLE>
You were lied to. No Del Sol has a b18. They either have D16Z6's or B16A3's. If you already have a hydro conversion, and the del sol it's out of is a Del Sol VTEC (b16a3), then yes, it'll work.
Old Sep 24, 2006 | 07:09 PM
lightcrx's Avatar
some also have D15's
Old Sep 24, 2006 | 08:31 PM
Syndacate's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
You were lied to. No Del Sol has a b18. They either have D16Z6's or B16A3's. If you already have a hydro conversion, and the del sol it's out of is a Del Sol VTEC (b16a3), then yes, it'll work.</TD></TR></TABLE>
Those and D15's
Either way, there was no sol's produced USDM (and as far as I know anyway) that had a B18 engine in them. You CANNOT put a del sol tranny on your block at all - as far as I know there's not even an adapter plate for a B engine to a D tranny. Gogo 100% custom work, might as well ******* make your tranny from scratch.
My advice: Find a B series motor, 99-00 si motor, del sol si VTEC (some models) (B16a), B18B (LS), B18C (GSR), B18C (ITR), B16B (CTR), so on and so forth. As far as I know, unless you go 100% custom, there's no way to put a del sol tranny on a b18 block. Go find a B tranny. No delsols came with a D tranny. Plus, if the del sol happens to be a B16 del sol, you're going to get *** fucked in mpg because you're going to be used to your older tranny...which is long...and then the B16 tranny is short as ****...so it'll fit..and you're gonna get pwned on the highway :-P
Find a B18 tranny.
EDIT:
If the block syas B18 then it's a LS swap and the tranny will fit. So unless you're looking at a swapped out del sol (non-original engine), you'll only get lucky with a B16 engine..in which case you'll get *** fucked in mpg Find an integra, any 94+ will fit 100%. Even a &lt;93 will work with a cable conversion but you already know that, so basically any integra tranny will work O.o.
Old Sep 25, 2006 | 04:12 AM
Tigerbyte's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">You were lied to. No Del Sol has a b18. They either have D16Z6's or B16A3's. If you already have a hydro conversion, and the del sol it's out of is a Del Sol VTEC (b16a3), then yes, it'll work.</TD></TR></TABLE>
D15B7 as well as B16A2 D16Y8 D16Y7 for 96-97
Modified by Tigerbyte at 6:35 AM 9/25/2006
Old Sep 25, 2006 | 11:08 AM
Default Re: (Tigerbyte)
Well I'm about to go see a '92 GSR cable tranny, the guy wants 350.00 dollars for it so lets see how that goes.. thanks for the advice.. I went to the junk yard to see what the block on those Del Sol say and it said D16 so there I knew it wouldn't work....
soulforce
May 16, 2006 09:15 PM
EJ8beast
23
May 8, 2006 08:18 AM
ZXVIIR
11
Jun 27, 2002 09:56 AM
