help a brotha out with iacv
Old Sep 24, 2006 | 03:01 PM
jaypot420's Avatar
Default help a brotha out with iacv
can somebody with an h22 take a picture of their iacv and where the hoses connect to for me? mine has no hoses connected to it and i would like to see where it goes to possibly fix my lumpy idle. i know it goes to the egr on one side, but cant quite locate it. my wiring might have been wired to remove the iacv, but the idle sucks and i would like to see if i can reconnect it to stable out the idle a little. i already checked the fiac and it seems pretty clean and functioning. the idle surges after warmup. if i take off the intake tubing and i put my finger on the upper most hole in the throttle body, i can stable the idle out by letting a little air come in, then let go and it idles fine. i believe that hole is connected to the iacv, right? so my next step it to get the iacv connected. what other things should i check for the idle. i have a vtec controller hooked in, i may just disconnect it and see if it improves. if anybody could help a brotha out, i would be very grateful!
1991civicb16
Jul 16, 2011 12:38 AM
teamXteg
Jun 13, 2008 11:08 PM
4ghatch
Sep 28, 2005 02:59 AM
blackZC (W)
Jun 21, 2004 05:58 AM
killa_lude
Aug 16, 2003 08:33 AM
