good block for b16
I just blew my b16a2 from my 99 si and its knocking real bad which means the bearing are messed up. So i need to fix my car soon, what shortblock can i attach to my head and everything that will work without modification. Basically what shortblock will give me a stock fit. Does it also have to be a obdII block or can it be obd1? Thanks alot for reading my noob question, just need a quick answer!
ditto that, I wouldn't try to change the type of block you have from a b16a. If you did then you'd have to deal with other issues( which I guess you don't want too.).
b18c5 EG
Jan 22, 2008 04:16 PM
mr. goodwrench
Nov 5, 2005 01:27 PM
