K-series rocker arms in B-series?
Old Sep 24, 2006 | 11:38 AM
MK Ultra's Avatar
Default K-series rocker arms in B-series?
This is something I've been wondering about for a while now.
Has anyone here experimented with the possibility of using the K-series' roller rocker arms in a B-series VTEC motor?
I've always wished I could afford some custom-made roller-rockers for my B-series, but that is not something I ever expect to be able to do. The cost would outweigh the benefits by far. But I do wonder if the spacing between the rocker arms is similar enough between the two engines, and if the B-series has enough clearance, to use K-series roller-rockers.
I don't really expect it to work, but I'm still curious. Since I don't have the parts just lying around to make the comparison myself, I thought I'd as if this has crossed anyone else's mind here.
Old Sep 24, 2006 | 07:53 PM
Black R's Avatar
25 Year Member
Default Re: K-series rocker arms in B-series? (MK Ultra)
I seem to remember a thread in the allmotor forum - probably in the archives by now.
Somebody was trying this out and it was pretty good in terms of compatibility.
The downside is that the angles are all off, so you'd need some custom cams, iirc.....
Old Sep 24, 2006 | 08:21 PM
mark_is_gay's Avatar
Default Re: K-series rocker arms in B-series? (Black R)
what are some of the con of running rocker arms? and bump for u trying to find ur answer
Old Sep 24, 2006 | 08:38 PM
RagingAngel's Avatar
Default Re: K-series rocker arms in B-series? (mark_is_gay)
weight is one of the issues as is the parasitic drag.
rollers will also let you run some very wild cam profiles too, or atleast with some pretty aggressive ramp rates.
Old Sep 24, 2006 | 08:50 PM
MK Ultra's Avatar
Ah, I was afraid the angles might present a problem, due to the thicker profile of the K-series rocker.
But yes, roller rocker arms allow for reduced friction (parasitic drag) in the valve train and often result in improved wear characteristics. Some old domestic V-8s respond to such a mod by belching out an extra 10+ hp. On a B-series, I wouldn't expect more than 2-3 hp., but in engineering terms it's simply a better way to do things.
Some engines don't use rocker arms at all, instead employing shims and tappets. I believe Toyota's 2JZ-GTE is an example of such a motor. The benefit of this kind of setup is eliminating weight from the valvetrain, allowing for higher operating rpm. Motorcycle engines also often use such a setup.
Old Sep 24, 2006 | 09:35 PM
jvtec95's Avatar
Doesn't Toda or someone make a roller-rocker conversion kit? I believe they mated up with the 'vtec killer' cams.
Old Sep 24, 2006 | 10:31 PM
MK Ultra's Avatar
Default Re: K-series rocker arms in B-series? (jvtec95)
Yes, but I don't want VTEC Killers.
Old Sep 25, 2006 | 12:37 AM
92TypeR's Avatar
FSAE
Web makes a roller rocker kit, and offers custom grinds.
Old Sep 25, 2006 | 08:33 AM
cmdr430's Avatar
pics from nopi 05
Old Sep 25, 2006 | 08:51 AM
MK Ultra's Avatar
Default Re: K-series rocker arms in B-series? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Web makes a roller rocker kit, and offers custom grinds.</TD></TR></TABLE>
Sweet.
Is their setup VTEC-compatable? Actually, I suppose I should look for myself....
[e] just looked at Web Camshafts' site. The only rocker arms I saw there were not roller rockers, but improved versions of the stock ones. Plus they require the elimination of VTEC.
Old Sep 25, 2006 | 01:12 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvtec95 &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't Toda or someone make a roller-rocker conversion kit? I believe they mated up with the 'vtec killer' cams.</TD></TR></TABLE>
No. Toda removes the vtec function, but still uses rocker arms that do not employ rollers.....
Ferrea is the mfr that comes to mind wrt roller rockers and custom cams to suit them.
Old Sep 25, 2006 | 01:42 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MK Ultra &raquo;</TD></TR><TR><TD CLASS="quote">
Sweet.
Old Sep 26, 2006 | 02:47 PM
Aquafina's Avatar
If you're going to use rollers, might as well just get the Ferrea setup. Benefits would be better without the added reciprocating weight. More oil available for the bottom end as well.
