is elite motorsports a good place to tune at?
ok so i live in canada, and i want to get my car tuned, but theres nothing around here really. elite is about 7 hours to drive to. anyone have experience there? can they tune NA setups as well?
Modified by B18 CYA at 3:40 AM 9/25/2006
Are there any that you can recommend for tuning an all motor setup? It's a pretty extensive setup, has a 1" deckplate, 13.5:1 cr, .5mm o/s valves etc.
Modified by B18 CYA at 9:30 PM 9/24/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adi Radoncic »</TD></TR><TR><TD CLASS="quote">Contact Dave (suprdave) at the Whipfactory, he is naperville IL.. I know its not MN but Dave is prolly the closest and best a/m tuning in this area...</TD></TR></TABLE>
well basically what im looking for is anything close to Winnipeg, Canada so that it wont expletive the tune up when i come back. were too far behind in the scene here and my motor wont make the power i want with what we have available for tuning.
edit : btw we are less than an hr drive from the US border of north dakota.
I wouldn't recommend going to elite. I would contact Jordan at consumate tuning. Great tuner, knows his stuff. Shane now works at DB performance in Rogers, MN. http://www.dbperformance.biz/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 »</TD></TR><TR><TD CLASS="quote"> The website of the Elite Motorsports you listed *was* located in Montclair, California. You must be thinking of a different elite. </TD></TR></TABLE>
hahah oops, my friend sent me the link for it. either way. im looking for the one in MN since its closer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">if you want to make all motor power in the minnesota area. you know where to go
i definatly do!!! i got a BAD *** setup that needs tuning bad!!!!
85mm b18c1
89mm crank
13.5:1 7cc arias pistons
cunningham rods 6.3770"
1" deckplate
RMF narrow header
.030 85mm cometic hg
fluidampr balancer
jdm gsr tranny w/lsd
gsr head, was ported local
.5mm o/s REV stainless valves/springs
crower Ti retainers
toda c cams
toda cam gears
70mm edelbrock throttle body
port matched skunk2 intake mani
prototype racing v-stack
</TD></TR></TABLE>i definatly do!!! i got a BAD *** setup that needs tuning bad!!!!
85mm b18c1
89mm crank
1" deckplate
RMF narrow header
fluidampr balancer
crower Ti retainers
toda c cams
toda cam gears
hahah actually i couldnt find the right timing belt!! it sat like that forever.
i tried every belt i could find from napa and none fit. what i had to do was switch out the gsr water pump (22T) for an LS (19T) and then i got a belt that was previously too short, and it ended up working!!!
