heat only works on 3 or 4 not 1 nor 2 help!!!!!
Old Sep 24, 2006 | 10:46 AM
b16civster's Avatar
Default heat only works on 3 or 4 not 1 nor 2 help!!!!!
like it says i know its the resistors but where are they??? pics are worth alot
Old Sep 24, 2006 | 10:50 AM
89 civic si's Avatar
Default Re: heat only works on 3 or 4 not 1 nor 2 help!!!!! (b16civster)
they should be in the kick panel sorry i dont have a pic
cbp_crx's Avatar
i dont have a pic handy, but if you take out your glove box, there will be a big white thing behind it, thats the blower motor housing, on the front of it, you will see a plug, unplug it, and take out the 2 screws holding it in, and thats it, i will see if i can find a pic
Old Sep 24, 2006 | 10:51 AM
Chiovnidca's Avatar
It's on the back of the blower motor housing. Remove the glove box for an easy shot at them.
Old Sep 24, 2006 | 10:52 AM
cbp_crx's Avatar
Default Re: heat only works on 3 or 4 not 1 nor 2 help!!!!! (cbp_crx)
https://honda-tech.com/zerothread?id=1436639 there scroll down its the first pic you will see
Old Sep 24, 2006 | 12:33 PM
janz3n's Avatar
i spent about 3 hours trying to replace my blower motor.. i ended up twisting the whole box thing it was hell. wish i knew about those two methods before.
Old Sep 24, 2006 | 01:43 PM
b16civster's Avatar
Default Re: heat only works on 3 or 4 not 1 nor 2 help!!!!! (janz3n)
thanks guys
Slapshotnerd
Dec 13, 2007 04:49 PM
DSRxSALSA
Welding / Fabrication
10
Oct 21, 2006 01:14 PM
DLB1994
Aug 5, 2001 09:25 AM
