eg swap questions
Old Sep 24, 2006 | 09:34 AM
drowzysleeper's Avatar
Default eg swap questions
i got a dx hatch that i want to put an ls in this will be my first swap so im a newb to it. for the questions can i use the stock ecu, wiring harness from an lx civic? also im wondering if i can use the stock integra motor mounts. im on a buget and out a car so i need the cheapest possible way to do the swap. thanks in advance
Old Sep 24, 2006 | 10:40 AM
coconutsoldier's Avatar
Default Re: eg swap questions (drowzysleeper)
If you can find a OBD1 LS engine, everything should work with your harness.
And you will need integra mounts. You will need the LS ecu as well.
preetyboi06
Jul 17, 2009 09:57 AM
jdmeg1075
May 8, 2009 09:35 AM
93sihatchy
11
Jun 10, 2007 03:40 PM
wutiteez
Aug 29, 2006 01:28 PM
Turbo_Mike
Jan 19, 2006 09:18 AM
