fs: full b series swap, basically everything in the engine bay!
hey guys whats up, i have decided to go k-series so it is time to sell my whole engine bay setup
now i can sell this as a full swap or part everything out. i am asking 5000 for the complete swap including motor, trans, hondata ecu, throttle cable, harness, mounts, shift linkage/shifter, fluidyne radiator, samco hoses..everything in the bay! now if nobody bites on that i will part it all out
transmission:
y21 b16 trans
ats 4.9 final drive
quiafe atb lsd
all new gearsets/seals/bearings
driveshaft shop stage 3 axles
2k miles on it, built by me absolutly flawless! used royal purple 10w-30 synthetic oil, changed once allready $2000 *also comes with old 4.4 final drive
engine:
B18A1 block
bottom end blueprinted and balenced
81.5mm 12.5:1 JE coated pistons w/ coated wrist pins
copper o-ringed
crower rods
stock crank lightened and balenced to 10k
arp head and main studs
z10 block girdle
mugen 160 thermostat
coated clevite bearings
toda oil pump gears
nuformz blockguard
act prolite flywheel
act 6 puck disc with extreme pp
type-r pickup, windage tray and pan
ctr n1 crank pulley
aem alt pulley
B16A head
twm 50mm itbs
GSR throttle cable
jegs liquid filled 0-100 fuel pressure gauge
twm rail and regulator
crower valvetrain
golden eagle ls-vtec head conversion
toda timing belt
rev ss valves
head ported by extrudehone
milled .005
skunk2 stage3 cams
crower cam gears
type-r lmas
rc 370cc sat injectors
msd 8.5mm wires
Profab tri-y header
modified type-r b-pipe
spoon n1 exhaust
Samco sport hoses
again 2k miles built by me flawless! castrol gtx reg oil used for the first 600 miles now on mobil 1 5w-30 full synthetic. had 8 oil changes so far (i change it every 200 miles or so) 215 across the board (huge cams drop numbers)
$2000 complete motor with catch cans and lines
short block $1200
head $800
ITBS $1500
Profab header $450
any questions just pm or hit me up on aim The2000lbDC
EVERYTHING IS ABSOLUTLY MINT ****** CONDITION THE ONLY REASON FOR THIS SALE IS BECAUSE I HAVE DECIDED TO GO K SERIES
i got endless vouches to assure you that it is all legit and exactly what i say it is, thanks!
rebuild threads:
https://honda-tech.com/zerothread?id=1466779
https://honda-tech.com/zerothread?id=1630238
https://honda-tech.com/zerothread?id=1725304
transmission:
y21 b16 trans
ats 4.9 final drive
quiafe atb lsd
engine:
B18A1 block
copper o-ringed
crower rods
z10 block girdle
toda oil pump gears
nuformz blockguard
ctr n1 crank pulley
aem alt pulley
B16A head
twm 50mm itbs
GSR throttle cable
crower valvetrain
toda timing belt
rev ss valves
milled .005
skunk2 stage3 cams
crower cam gears
type-r lmas
msd 8.5mm wires
Profab tri-y header
spoon n1 exhaust
Samco sport hoses
short block $1200
head $800
ITBS $1500
Profab header $450
rebuild threads:
OMG, you are parting out too???
It all just makes me wanna go K too
Well, not now... but when I have money and all. Hahahahaha
its hard to keep up with the mid-atlantic thread, new parts added on this one http://hondamarketplace.com/zerothread?id=1761317 thanks!
