Lightest Battery ?
Old Sep 23, 2006 | 08:18 PM
Rob.'s Avatar
Default Lightest Battery ?
Looking to buy a lightweight battery. Anyone know which battery is the lightest ?
So far I have found these.
Hawker (Enersys) Genesis G13EP
compared to stock size (10.8 lbs vs 30lbs) --> lightest I found.
T1R lightweight battery (www.aj-racing.com) (13.5lbs)
Braille Auto (11.5lbs) (www.brailleauto.com)
Buddy Club (16.5lbs)
Odyssey PC 680MJT (15.4lbs)
Old Sep 23, 2006 | 09:29 PM
user 72830283's Avatar
damn...now i wish i had gotten the hawker... but i have the odyssey..and at 15 some lbs... thats light enough..
but i think the hawker might just be the lightest..from your research.. i always thought the odyssey and the heel toe were the lightest..
Old Sep 23, 2006 | 09:56 PM
ic's Avatar
ic
Default Re: (pr3d)
i think hawker & odyssey are the same company (or something).
You should make sure you're comparing the Batt. output capabilities as well. Some of the really small batteries may be insufficient for a daily driver.
BTW. I use the Odyssey 680 for my daily driver. Never had any probs. Just don't run your stereo, etc. while the engine is off. (duh)
Old Sep 23, 2006 | 10:08 PM
jdmazm's Avatar
Default Re: (ic)
optima batteries pwn!!1
Old Sep 23, 2006 | 11:22 PM
RCautoworks's Avatar
Default Re: Lightest Battery ? (Rob.)
Why the lightest, why not the most efficient ? You do know some of these batteries don't last that long right ?
Old Sep 24, 2006 | 04:31 AM
88 rex's Avatar
Default Re: Lightest Battery ? (90blackcrx)
I don't think the G13p is strong enough.
Old Sep 24, 2006 | 05:07 AM
bag's Avatar
bag
i got odysey hawker from batterymart.com it starts up no problem no matter what time of the year,i never even wanted a small battery like that till i saw this guy at e-town with it,i believe hes on here ,green crx with b16 and it had conn. plates..i think his name is mike i dont know thogh
Old Sep 24, 2006 | 05:14 AM
Rob.'s Avatar
Default Re: Lightest Battery ? (bag)
The braille auto one is only 11.5lbs. I think Im gonna get this one.
Old Sep 24, 2006 | 05:16 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">The braille auto one is only 11.5lbs. I think Im gonna get this one. </TD></TR></TABLE>
That's like $100 more than an odyssey with the bracket. I'm sure for $100 you can find a way to save 3 lbs.
Your money though, not mine.
Old Sep 24, 2006 | 05:46 AM
Autoworks's Avatar
Are you looing at any specs on these batteries other than just the weight??
Old Sep 24, 2006 | 05:48 AM
Rob.'s Avatar
Default Re: Lightest Battery ? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">Are you looing at any specs on these batteries other than just the weight??</TD></TR></TABLE>
I dont know what the specs mean.. can you explain to me ?
How do they compare to a regular Crx battery ?
BTW: I have the same interstate battery in the 1st pic.
Old Sep 24, 2006 | 06:15 AM
Autoworks's Avatar
BTW: I have the same interstate battery in the 1st pic.</TD></TR></TABLE>
dimensions, capacity and cranking amps
I use the Odyssey batteries, sure they aren't the lightest, but they work fine. If the lightest battery is2 lbs. lghter but $100 dollars more than the next lightest...is it really worth it? You could be getting "less" battery for more money; which would be a waste IMO.
Old Sep 24, 2006 | 07:02 AM
EF Sedan Enthusiast's Avatar
What's the best price people have been getting the Odyssey PC680MJT for?
Old Sep 24, 2006 | 07:34 AM
See Are Ex's Avatar
I use a 25 dollar walmart lawn tractor battery. Can't weigh any more then 10 pds, 200 cca's and runs my b16 crx daily, and my dads b18 hatch all summer with no problems. You can even run ur stereo without worries. for a short period anyways.
Old Sep 24, 2006 | 08:06 AM
fireant's Avatar
Default Re: (See Are Ex)
My 11lb Hawker G13 is plenty strong for me for years now...outlasted 3 conventional batteries in my other car.
Except you're in Canada right? You should go with a 15lb-er like the PC680 to ensure super-cold morning starts are stronger.
Old Sep 24, 2006 | 08:51 AM
black88si's Avatar
Default Re: (fireant)
I live in WA state and have been running a hawker PC680 in my ZC rex for over a year now. Never had a problem.
Old Sep 24, 2006 | 09:11 AM
SiCRX90's Avatar
Default small battery
i always used a mazda miata battery in my crx...its small and very light
Rob.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">My 11lb Hawker G13 is plenty strong for me for years now...outlasted 3 conventional batteries in my other car.
Except you're in Canada right? You should go with a 15lb-er like the PC680 to ensure super-cold morning starts are stronger.</TD></TR></TABLE>
I dont drive the crx in wonter months. Early November latest !
Old Sep 24, 2006 | 01:12 PM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are Ex &raquo;</TD></TR><TR><TD CLASS="quote">I use a 25 dollar walmart lawn tractor battery. Can't weigh any more then 10 pds, 200 cca's and runs my b16 crx daily, and my dads b18 hatch all summer with no problems. You can even run ur stereo without worries. for a short period anyways.</TD></TR></TABLE>
hell yeah for the HMT thinking.
Old Sep 24, 2006 | 01:18 PM
2lude4u's Avatar
Default Re: (shortyz21)
The Braille Battery worked great for me in California, but now that it's getting cold here in Utah I had to pull it out after it failed to crank my car one cold morning, so those of you that live in colder climates should go with something a little bigger.
Old Sep 24, 2006 | 02:37 PM
Default Re: Lightest Battery ? (jdm_ef3)
Most of these small batteries will not last in the winter ( cold )
Old Sep 24, 2006 | 03:07 PM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Most of these small batteries will not last in the winter ( cold )</TD></TR></TABLE>
I &lt;3 Florida!!!!
Old Sep 24, 2006 | 04:42 PM
Crx Jimmy's Avatar
Default Re: Lightest Battery ? (Cobra Tim)
this you list as the pc368 MJT the mj is for metal jacket which weighs a couple pounds, you can get this battery without the metal jacket and weighs less same with the heavy automotive terminals remove those they are solid brass and weigh a lot, maybe 1lb? just use ring termimals, I have this battery and it does start in cold below 0degreeF weather. I got mine from some website they were in FL It was way cheaper than batterymart i think it was $75
Old Sep 24, 2006 | 07:07 PM
fireant's Avatar
After seeing some champion autoxer running his 89 si hatch on one, I must admit when the Hawker G13 finally dies, I will probably give this a try too.
Old Sep 25, 2006 | 04:45 AM
Bserieskllr's Avatar
my friend has had alot of problems with the braile battery
