Honda S2000 Honda S2000
Krank Vents - More HP/$$$ than JDM
Old Sep 23, 2006 | 06:55 PM
kane.s2k's Avatar
Default Krank Vents - More HP/$$$ than JDM
Here's the dyno of a very new AP2 with a baseline and the krank vents installed immediately afterwards:
Red - Baseline
Blue - Krank Vent installed
The krank vents picked up 2-3whp all over the rpm range except at the very last 100rpm. It would have made even more HP if the car wasn't run back to back. The engine was hotter the krank vent run so that lowered the overall gains a bit. I think he could have gotten more HP if it was let to cool down to equivalent engine temps. Also if I had gotten a engine with higher milage and greater ring wear, it would have made even larger gains.
So, for $110 you not only get lowered oil consumption as realized by many people already, you also pick up a few ponies. Around the same as some intakes and exhausts that cost thousands
And for all the people who thought this didn't make any gains and was just a waste of money (even though everyone who bought one all felt a difference with their engine running smoother and the F/I guys had huge reduction in oil consumption)
http://automotivespeed.com/pro...id=49
Old Sep 23, 2006 | 07:09 PM
Mase's Avatar
Default Re: Krank Vents - More HP/$$$ than JDM (kane.s2k)
i can make more gains than that without changing anything depending upon how i run the dyno pulls....
im not convinced
Old Sep 23, 2006 | 07:20 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Krank Vents - More HP/$$$ than JDM (Mase)
waste of $$$...
get a $5 1 way check valve adn route it to your exhaust and BOOM instant vac is created to pull the crank case pressure
Old Sep 23, 2006 | 07:22 PM
kane.s2k's Avatar
Old Sep 23, 2006 | 08:27 PM
Sideways's Avatar
I installed them and my oil consumption dropped over 90% and the boost increased slightly. It was apparently from the pcv valve not holding against boost.
Old Sep 23, 2006 | 09:05 PM
noturtypicalone's Avatar
Default Re: Krank Vents - More HP/$$$ than JDM (Sideways)
i would burn 1 qt every 3000miles. .now i burn nothing. .
hardly a waste of money
Old Sep 23, 2006 | 10:12 PM
liam821's Avatar
25 Year Member
Default Re: Krank Vents - More HP/$$$ than JDM (noturtypicalone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noturtypicalone &raquo;</TD></TR><TR><TD CLASS="quote">i would burn 1 qt every 3000miles. .now i burn nothing. .
hardly a waste of money </TD></TR></TABLE>
I dont have any of that, and my s2000 burns nothing. Zero oil usage every 3000 miles.
liam
Old Sep 23, 2006 | 11:00 PM
kane.s2k's Avatar
Default Re: Krank Vents - More HP/$$$ than JDM (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">I dont have any of that, and my s2000 burns nothing. Zero oil usage every 3000 miles.
liam</TD></TR></TABLE>
Then you are pretty fortunate. My car used to burn 1qt every 3,000 miles as well. Some of my close friends had the same.It's also pretty well documented that many people have some pretty high oil consumption issues.
Old Sep 25, 2006 | 10:38 AM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">
Then you are pretty fortunate. My car used to burn 1qt every 3,000 miles as well. Some of my close friends had the same.It's also pretty well documented that many people have some pretty high oil consumption issues.</TD></TR></TABLE>
Would lead my to believe that these engines weren't broken in properly or the choice of oil. Mobil 1 is notorious for burning. Since I switched to synthetic oil(Castrol/Motul) 3 years ago, my 02's engine hasn't burned a drop of oil since.
Old Sep 25, 2006 | 11:11 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Krank Vents - More HP/$$$ than JDM (ITRbroham)
Mine burns about a quart every 3000. Sometimes more, if it is driven hard.
Old Sep 25, 2006 | 04:08 PM
revhi's Avatar
I have the krank vetns to, I think they are a great concept.
My car never burns oil, I redlined the car on the test drive and ever since, Im FI, Ive run lean for a few months.
Each cars just different, I use Castrol GTX.
Old Sep 25, 2006 | 05:07 PM
AlphaKennyWun's Avatar
Default Re: (revhi)
my car doesnt burn oil although it is new, only 1500 miles. The manual says to check the oil level every time you fill up with gas
I should be used to it though, my turbo teg used to burn a qt or more every 1000 miles.
Modified by S2K.Chris at 1:37 AM 9/26/2006
Old Sep 25, 2006 | 09:06 PM
Francesco's Avatar
Default Re: (S2K.Chris)
each car is different
from what i have read these are supposed to be a very effective mod.
Old Sep 26, 2006 | 12:10 AM
rice r0cket's Avatar
$110 to save a $4 quart of oil every 3k miles?
Old Sep 26, 2006 | 03:41 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Krank Vents - More HP/$$$ than JDM (stealthx32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthx32 &raquo;</TD></TR><TR><TD CLASS="quote">
$110 to save a $4 quart of oil every 3k miles?</TD></TR></TABLE>
It is worth the piece of mind to me knowing that my car isn't burning oil IMO.
Old Sep 26, 2006 | 05:46 AM
JDM knowledge's Avatar
Default Re: Krank Vents - More HP/$$$ than JDM (HybridHatch88)
nice mod. I dont get the point behind the title but whatever.
Old Sep 26, 2006 | 07:19 AM
kane.s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthx32 &raquo;</TD></TR><TR><TD CLASS="quote">$110 to save a $4 quart of oil every 3k miles?</TD></TR></TABLE>
Or to make sure your engine isn't having a chance of detonating because of the oil lowering your octane.
Old Sep 26, 2006 | 10:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">Or to make sure your engine isn't having a chance of detonating because of the oil lowering your octane.</TD></TR></TABLE>
Yeah, because 1 quart of oil every 150-200 gallons of gas is really gonna have an effect on my average octane...
Old Sep 27, 2006 | 09:31 AM
fred92htch's Avatar
How about some pics.
Old Sep 27, 2006 | 09:36 AM
kane.s2k's Avatar
Here's a picture of it installed with sort of installation instructions on sideway's car:
Old Sep 27, 2006 | 11:26 AM
evil vapor's Avatar
Yeah, because 1 quart of oil every 150-200 gallons of gas is really gonna have an effect on my average octane...</TD></TR></TABLE>
on a highly modified car where you don't have a lot of room for error, the lowered octane can decrease the life of a hard-run engine.
Old Sep 27, 2006 | 11:48 AM
kane.s2k's Avatar
Lets not forget the oil getting on the plugs and the increased carbon build up everywhere else. That 1qt. really adds up.
Old Sep 29, 2006 | 06:58 AM
fred92htch's Avatar
Default Re: (kane.s2k)
I'm not quite following this, is this an issue only on boosted engines? What about N/A?
Old Sep 29, 2006 | 08:39 AM
kane.s2k's Avatar
The dyno charts are off an N/A car. It was originally brought into the S2000 market for the F/I guys but found that it gave similar benefits to the N/A guys.
Old Sep 29, 2006 | 11:28 AM
Just Joey K20's Avatar
