rear brakes dont work
Old Sep 23, 2006 | 04:14 PM
k624ash's Avatar
Default rear brakes dont work
I just did an abs removal on my 95 integra using an si prop valve. after i was done i went to bleed the brakes and the rear brakes wouldnt bleed, no fluid or air. i then relized that when you push the pedal down the caliper also doesnt grab the rotor.
the front brakes work just as they should but both of the rear brakes arent working at all, any help would be greatly appriciated
dank24
Apr 3, 2007 02:57 PM
k624ash
Sep 25, 2006 08:54 AM
staticrex
May 12, 2004 01:32 PM
