Finally some track times for my 320whp LS/V-T
Old Sep 23, 2006 | 01:07 PM
Topdawgg's Avatar
Default Finally some track times for my 320whp LS/V-T **NEW TIMES OCT 1st ***
Well... i picked a bad weekend to go to one of the tracks close by.. but I went anyways..
It was Nova Scotia Drag Racers Association (NSDRA) finals there this weekend... so 240 cars racing....
Only got 2 runs in..
13.3 @ 109mph
2.0 60ft
1.4 reaction time
second one was
12.9@111mph
2.1 60ft
.83 reaction...
Was improving alot, and this was my first time racing with slicks, and first time racing my car boosted....
I was pleased, im hopin for low 12s, high 11s after some practice.... 2 runs just doesnt cut it..
Modified by Topdawgg at 6:02 PM 10/1/2006
Old Sep 23, 2006 | 02:03 PM
Topdawgg's Avatar
and a video...
racing some 12.5 car in the gamblers race
http://media.putfile.com/129-CIVIC
Old Sep 23, 2006 | 02:11 PM
20yrsToMidnight's Avatar
Default Re: (Topdawgg)
nice your making some good power on low boost what turbo are you using? with some more practice you should definatly see better times !
Old Sep 23, 2006 | 02:17 PM
Topdawgg's Avatar
Heres the setup
B18a block 81.5mm bore
Wiseco 9.4:1 Pistons
Eagle H Beam rods
ARP Head studs
jdm b16a head
94-01 GSR cams
AEBS Intake MAnfold
RC 750cc injectors
GM 3 bar map sensor
Garrett T304E 60 Trim .63 A/R
TIAL 38mm wastegate..
custom ram style manifold
3 inch DP
3 inch Catback
Precision 350hp intercooler
the wastegate is set at 8psi.... and it creeps to around 11-12 in vtec
Old Sep 23, 2006 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">the wastegate is set at 8psi.... and it creeps to around 11-12 in vtec</TD></TR></TABLE>
Nice set up why the boost creep though with a tial?
Old Sep 23, 2006 | 02:40 PM
Topdawgg's Avatar
not too sure, could be the flow in my manifold, could be the vaccuum source not close enough to the turbo
Old Sep 23, 2006 | 05:05 PM
komat's Avatar
what slciks are you using. your 60ft should be lower
Old Sep 23, 2006 | 05:10 PM
93supercoupe's Avatar
Default Re: (komat)
Its not the wastegate that makes it creep, its the wastegate placement on the manifold.
Old Sep 23, 2006 | 05:23 PM
Topdawgg's Avatar
Default Re: (komat)
my slicks were 22x8's on 13 inch bmw wheels... at about 16psi of pressure....
M/T drags
Old Sep 23, 2006 | 05:55 PM
spooncivic1's Avatar
turn that **** up!!! 400whp isn't out of the question...that would be hunting territory for high 10's
Old Sep 24, 2006 | 12:09 AM
komat's Avatar
Default Re: (spooncivic1)
are you building boost off the line?
Old Sep 24, 2006 | 01:45 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (komat)
with that trap times youd be very very lucky to hit 11's but low 12's aren't out of the question
Old Sep 24, 2006 | 06:02 AM
Topdawgg's Avatar
this is also one of the slower tracks in my region.... it is slightly up hill and there are 2 other faster tracks...
Old Sep 24, 2006 | 06:59 AM
11SEC CIV's Avatar
lower the tire psi..start off around 10 then work your way down
Old Sep 24, 2006 | 08:11 AM
Topdawgg's Avatar
like i said, first time racin with slicks, and first time racin a boosted honda..... so it was all trial and error.... little things i can work on
Old Sep 24, 2006 | 09:29 AM
sp00led's Avatar
Same slicks, same power level i ran consistant 1.8 60's. That was my first time out so im sure there is room for improvment. I noticed running about 8psi in my slicks and launching at 7500rpm worked best.
What were your 1/8 times?
Old Sep 24, 2006 | 09:39 AM
Topdawgg's Avatar
lemme run down to the car and grab my 2 slips
Old Sep 24, 2006 | 09:44 AM
Topdawgg's Avatar
just had my 1/8th mph, no times for the 1/8
Old Sep 24, 2006 | 09:45 AM
blackeg's Avatar
Default Re: (11SEC CIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">lower the tire psi..start off around 10 then work your way down</TD></TR></TABLE>
. absolutely. i run my drag radials at 10psi.
when you go and do a burnout, you increase the pressure in the tire because it heats up and expands (not much but still).
for the creep, its a mix of wastegate placement and design. i used to get some creep, and my wg hole out of the manifold was no where near the 1.5" it shoulda been.
i think you'll wind up being consistant in the low 12's, but its gonna take some time. it took me about 10-12 passes to work out some different things and become consistant in the mid 12's. trial and error, seat time are your friends. practice makes perfect!
Old Sep 24, 2006 | 10:55 AM
mra4886's Avatar
what was the 1/8mile mph then. and yes some improvement needed. with that reaction time.
Old Sep 24, 2006 | 11:35 AM
Topdawgg's Avatar
86.21 first run 1/8 mph
89.16 2nd run 1/8 mph
Old Sep 24, 2006 | 11:37 AM
hondaboyB18C1's Avatar
Bammm.....fast turbo Civic
Old Sep 24, 2006 | 11:57 AM
mra4886's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">86.21 first run 1/8 mph
89.16 2nd run 1/8 mph</TD></TR></TABLE>
with those mphs you were probaly in the mid 8's
Old Sep 24, 2006 | 01:44 PM
Topdawgg's Avatar
Default Re: (mra4886)
good, bad 1/8th mile?
Old Sep 24, 2006 | 02:32 PM
HamiltonRex's Avatar
slick pressure too high.. 60fts hurting you. Tire pressre at 7psi. I had similar traps as you, good for mid 12's.
