Help! Bottom mount bolt wont come out.
Old Sep 23, 2006 | 12:27 PM
Linh.'s Avatar
Default Help! Bottom mount bolt wont come out.
Started to take out the driver side bottom mount off. Got the first bolt off then tried to get the second one out. The bolt came out half way and started to spin. How can I get this bolt out?
Old Sep 23, 2006 | 12:29 PM
philosofy1's Avatar
Default Re: Help! Bottom mount bolt wont come out. (Linh.)
damn, sounds like it's stripped. do you or are you using a air impact gun?
Old Sep 23, 2006 | 12:33 PM
Kruzen510's Avatar
So is the nut in the frame rail broken off? is that whats spinnin?
Old Sep 23, 2006 | 12:35 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: Help! Bottom mount bolt wont come out. (Kruzen510)
i owuld bet its the nut on the other side that broke off...clamp that and it should come out
Old Sep 23, 2006 | 12:43 PM
philosofy1's Avatar
Default Re: Help! Bottom mount bolt wont come out. (teamvirus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus &raquo;</TD></TR><TR><TD CLASS="quote">i owuld bet its the nut on the other side that broke off...clamp that and it should come out </TD></TR></TABLE>
nut on the other side? WTF? did you look at the picture. with that mount there is no nut.
goes to show typical H-T. one person says a specific answer then there is like 10 more members with the same answer.
Old Sep 23, 2006 | 12:48 PM
teamvirus's Avatar
Default Re: Help! Bottom mount bolt wont come out. (philosofy1)
where does the bolt screw into?? a nut welded to the other side!! dont talk **** if you have never looked at a car
i know this cause my driver side mount "nut" broke off
Old Sep 23, 2006 | 12:53 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus &raquo;</TD></TR><TR><TD CLASS="quote">where does the bolt screw into?? a nut welded to the other side!! dont talk **** if you have never looked at a car
i know this cause my driver side mount "nut" broke off</TD></TR></TABLE>
sorry noobie, but i have looked at a car, plenty of times. and if haven't noticed he's replacing the lower driverside mount not upper. the upper one has the welded nut, genius!
the lower one is feed through the chassis that is already threaded. better do your homework before running at the mouth with me!
Old Sep 23, 2006 | 12:56 PM
teamvirus's Avatar
lol, then whats wrong with his bolt?? lets say its stripped, y would it spin?? makes no sence at all
Old Sep 23, 2006 | 12:59 PM
Kruzen510's Avatar
It may not be an actual nut but it is a nut plate welded to the inside of the frame rail.
Old Sep 23, 2006 | 01:00 PM
Linh.'s Avatar
Yes I was using an impact gun but I was slowly backing it out. About half way it start to just spin and wont come out.
Old Sep 23, 2006 | 01:01 PM
Kruzen510's Avatar
cut the the bolt off for now.
Old Sep 23, 2006 | 01:03 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus &raquo;</TD></TR><TR><TD CLASS="quote">lol, then whats wrong with his bolt?? lets say its stripped, y would it spin?? makes no sence at all </TD></TR></TABLE>
i just replaced mine about a month and half ago. like i said the chassis had threading, no signs of a nut. if there is a nut like you claim, then how will he reach into the chassis to replace it, since he has no access from no where.
apparently you never stripped a bolt going in, then went to take it out again and it keeps spinning. had this happen to my oil pan bolt. you mean to tell me there is a nut holding the pan bolt too?
TO THE OP, get a long screwdriver or a prybar. apply some pressure on it and take the socket and begin to unbolt it. it should come out with the pressure on it.
depending how bad the threads are you can either re-thread it or get an helicoil.
Old Sep 23, 2006 | 01:04 PM
kbsoldier's Avatar
if u r doing a swap with hasport motor mounts you dont even need that bolt....just cut it off....
Old Sep 23, 2006 | 01:07 PM
Linh.'s Avatar
Default Re: Help! Bottom mount bolt wont come out. (kbsoldier)
I'm not worried about the mount I just need that bolt off. Since I'm throwing my h22 motor into it.
Old Sep 23, 2006 | 01:09 PM
Kruzen510's Avatar
Then whats the big deal? Cut it off, end of story.
Old Sep 23, 2006 | 01:17 PM
ProJectCvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">i just replaced mine about a month and half ago. like i said the chassis had threading, no signs of a nut. if there is a nut like you claim, then how will he reach into the chassis to replace it, since he has no access from no where.
depending how bad the threads are you can either re-thread it or get an helicoil.</TD></TR></TABLE>
There is a welded nut on the the opposite side of the chasis....I broke the welds off mine too and had the same thing happened as the OP. I ended up cutting the bolt, creating a bigger hole and welded a new nut on so it sits flush. The nut is still in the frame....doesn't hurt.
You can run your stubbon mouth all you want....
Honda would be dumb to "thread a sheet metal that is not even 1/8" inches. Consider the time to thread and consider the time to tack a nut. Which is stronger? which is faster?
Old Sep 23, 2006 | 01:40 PM
Linh.'s Avatar
Default Re: Help! Bottom mount bolt wont come out. (ProJectCvic)
Yepp I just took a hacksaw to the bolt and there is a nut welded to the frame. I guess the welds broke when I was using the impact.
Old Sep 23, 2006 | 01:42 PM
make the hold bigger and weld a nut in flush with the surface.
Old Sep 23, 2006 | 01:46 PM
Linh.'s Avatar
No need h22 swap! But does that bolt rattle in your frame?
Old Sep 23, 2006 | 01:47 PM
nope..not that I noticed
Old Sep 23, 2006 | 02:17 PM
Kruzen510's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">
Honda would be dumb to "thread a sheet metal that is not even 1/8" inches. Consider the time to thread and consider the time to tack a nut. Which is stronger? which is faster? </TD></TR></TABLE>
x2
Old Sep 23, 2006 | 04:07 PM
EK9Greg's Avatar
I would cut the bolt off to get the mount out of the way then try to drill it out then retap it thats about it really you also can just make a new hole in the mount then drill a new hole in the frame and tap it thats really about it or just weld the mount to the frame or just don't use it
Old Sep 23, 2006 | 04:37 PM
ogawa_jiei's Avatar
Default Re: Help! Bottom mount bolt wont come out. (Jarfal)
Edited
the_0ne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jarfal &raquo;</TD></TR><TR><TD CLASS="quote">an easy way to open the bolt
take a strong flat screwdriver and a hammer
hit the screwdriver on the edge of the bolt counter clock wise</TD></TR></TABLE>
hammer the expletive out of it/vice grips
Old Sep 24, 2006 | 02:09 AM
teamvirus's Avatar
lol
