Transmission/clutch problems D15
Old Sep 23, 2006 | 07:51 AM
scottybfh's Avatar
Default Transmission/clutch problems D15
Hello all, I'm new to honda-tech forum and I have a problem. My 95 civic dx has been running great up until lately. Starting about a week ago or so, when I would release the clutch to gear down to accelerate or deccelerate, there is this grinding sound as it goes into the lower gear. Anyone ever run across this before? I'm not sure if its the clutch or the tranny but I replaced the clutch about two years ago and I'm a pretty easy driver so I doubt its that. And it also cuts off if I try and take off in 5th gear (a test I heard of to test the clutch). The sound is also heavily present when I am driving in first gear and slightly in second gear. So, my guess is that its the tranny but I wanted to run this by you and get your opinion from more experienced Honda peeps. Any help and advice would be greatly appreciated. Thanks!
Scottybfh
Old Sep 23, 2006 | 08:12 AM
nsxmatt's Avatar
Default Re: Transmission/clutch problems D15 (scottybfh)
Sounds like a input shaft bearing. It actually makes noise in every gear it's just more noticeable when your going slower. It's hard to describe a noise over the internet, might be better to find someone local that does transmission work and have them listen to give you a better idea.
Old Sep 23, 2006 | 08:23 AM
scottybfh's Avatar
Default Re: Transmission/clutch problems D15 (nsxmatt)
thank you for your post. so, to you, does it sound like I might need a new tranny? and if so, do you know where I might find a cheap replacement? thanks again!
Old Sep 23, 2006 | 08:32 AM
nsxmatt's Avatar
Input shaft bearings require a complete teardown and rebuild so the labor may kill you. You can usually find a good used unit in the classifieds here or sometimes at a salvage yard.
Old Sep 23, 2006 | 11:39 AM
Bense's Avatar
i will be in charlotte on oct 7th for the honda-tech meet. I can sell you a rebuilt ex transmission with parts that are used, but inspected and good condition for $200
no grinding gears, no gears popping out, or anything of the sort
Old Sep 23, 2006 | 01:09 PM
scottybfh's Avatar
Default Re: Transmission/clutch problems D15 (Bense)
Might sound like a dumb question but does an EX tranny hook up to a DX motor and will there be any problems later? Thank you for your reply!
scottybfh
Old Sep 23, 2006 | 03:47 PM
Libertariat's Avatar
Ek Forever y0!
That's not a dumb question. Yes, all D-series transmissions will hook-up,
And if you're a spirit-y driver you will enjoy an ex transmission. It has much shorter gear ratios and still gets good mpg. But with a -series it's hard to get bad gas mileage.
So if you do replace it, go for the Ex tranny.
Old Sep 23, 2006 | 06:28 PM
scottybfh's Avatar
Default Re: Transmission/clutch problems D15 (ek forever guy)
great! thank you very much ek for the info!
Old Sep 23, 2006 | 11:15 PM
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">That's not a dumb question. Yes, all D-series transmissions will hook-up,
Care to wager $100 on that statement?
I know Bense nor Bauley will challenge.........
Old Sep 24, 2006 | 03:27 PM
Ek Forever y0!
Default Re: Transmission/clutch problems D15 (Mista Bone)
as long as it's in his gen and it's a zc or hax trans. But yeah, pretty much all ex/dx/cx will match.
k Thanks bye
Old Sep 24, 2006 | 03:30 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scottybfh &raquo;</TD></TR><TR><TD CLASS="quote">Might sound like a dumb question but does an EX tranny hook up to a DX motor and will there be any problems later? Thank you for your reply!
scottybfh</TD></TR></TABLE>
I can assemble it with dx gears, whichever you prefer.
3.25, 3.722, 4.058, or 4.25 final drive, whichever you prefer
stock for your car is 4.058
higher number = greater acceleration and lower top speed
lower number = lower acceleration and greater top speed
some like long gears for mpg
some like short gears for accel
it's all in your preference
Old Sep 24, 2006 | 06:16 PM
qpracer's Avatar
I have I think the same problem. I hear a chatter noise (varies in sound according to how i let out the clutch and how warm the motor or weather is-- also causes minor swearing inside the car) when I let out the clutch. I have been told that the flywheel needs resurfacing. I can only guess that this is because of dumping the clutch when drag racing (which i no longer do because autocross is WAY more fun in a civic).
I can also hear a 'knacking' noise (frequency goes up when speeding up) once I leave in first gear, and a little in second, but fades away because i cant hear it at speeds above 15-20 mph. i have no idea what this could be, but maybe engine related if it occurs at same RPM? Any help?
So thats all i know.... That my trans is a lost cause. i will be getting a new one soon
Old Sep 27, 2006 | 04:48 AM
scottybfh's Avatar
well, should i go with the dx or ex tranny? anyone have any pros/cons to say about that?
Old Sep 27, 2006 | 05:03 AM
iDeNtiTy
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scottybfh &raquo;</TD></TR><TR><TD CLASS="quote">well, should i go with the dx or ex tranny? anyone have any pros/cons to say about that?</TD></TR></TABLE>
EX tranny has shorter gears imo, go with EX you will puill harder
Old Sep 27, 2006 | 09:07 AM
crimsonv4mpire's Avatar
if you're interested i have a dx tranny with new bearings in pa, pm me if interested
mxl36o
Aug 24, 2006 09:14 PM
Aphelion
Apr 24, 2005 03:16 PM
nd8ch
Jan 29, 2004 09:52 AM
nd8ch
31
Jan 28, 2004 10:03 AM
