Interior light question
Old Sep 23, 2006 | 07:29 AM
b18c-ivic_gsR's Avatar
Default Interior light question
Ok i took the radio out of my car and the interior light doesn't work, which i knew this was already going to be the case but i forgot which wires i had to jump to get it to work with out the radio installed and i was wondering if anyone knew, i have already done a search but didnt find anything related. any help is apreciated thanks.
Old Sep 23, 2006 | 07:47 AM
viper1984's Avatar
did you check the fuse??
Old Sep 23, 2006 | 11:03 AM
Default Re: (viper1984)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viper1984 &raquo;</TD></TR><TR><TD CLASS="quote">did you check the fuse?? </TD></TR></TABLE>
in other words im eliminating the radio but i still want my interior light to work i need to know what wires to jump on the green plug so the light still works with out the radio.
Old Sep 23, 2006 | 11:05 AM
EdWord's Avatar
Default Re: (b18c-ivic_gsR)
eh samething for my brother, though he didnt take out the radio,he has an ek and the light used to work, but for some reason its not turning on anymore
Old Sep 23, 2006 | 12:11 PM
Default Re: (mR PHANTASTIC)
ok i got the honda service manual and found the wires that have to be jumped, just in case anyone else wants to know here they are:
Old Sep 23, 2006 | 12:15 PM
philosofy1's Avatar
umm...i'm trying to understand. you're removing the radio, but still want your dome light to work? shouldn't work anyway, with or without the radio there?
Old Sep 23, 2006 | 12:22 PM
Default Re: (philosofy1)
ok this might just be for civic hx's or whatever other models that have the remote security system built in to the radio but when you remove the radio theres 2 green plugs you have to unplug also those are for the security module once you unplug this the dome light doesnt work nor the keyless entry but my keyless crap never has worked so its no loss to me i just wanted the dome light to still work.
Old Sep 23, 2006 | 12:28 PM
philosofy1's Avatar
ahh...i understand now. well, did you try to jump them. meaning connect them together. for example, when doing a auto to manual swap, to get the car to turn on and work, you have to connect the 2 thickest wires at the console. doing this tricks the car into thinking the car is parked and then you can start, and take out the key to the car.
maybe it's a similar setup, wouldn't hurt to try.
Old Sep 23, 2006 | 01:27 PM
yes i jumped them and it worked perfectly.
traxxasx
Mar 12, 2008 07:17 PM
Ex-Eg-Driver
Sep 21, 2007 12:33 AM
neocrynym
Nov 16, 2004 11:06 AM
SLOAZZ95
Oct 6, 2003 11:55 AM
E dwinbon G
May 27, 2003 09:41 AM
