Fuse keeps blowing! please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by down_the_hatch »</TD></TR><TR><TD CLASS="quote">My instrument/license plate/taillight fuse keeps blowing. would anyone know why?
mike</TD></TR></TABLE>
If this is for a eg civic then most likely you pinched one of the interior wires in between the upper and lower console (the ashtry has a metal protector above it and LOTS of times it pinches a wire and grounds it out).
Just look at whatever you took apart last... thats most likely the problem.
I had the same problem...
It wound up being the aftermarket radio adaptor harness' illumination wire grounding out. You know how they pre-cut the end of the wires so it's an easy connection? My radio didn't use the orange illumination wire so I left it unhooked. Just my luck it grounded.
It'd be worth it to check out if you've recently installed a radio. Otherwise check all the other current-carrying wires in and around the radio area. I'm betting it's around there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal93eg »</TD></TR><TR><TD CLASS="quote">I had the same problem...
It'd be worth it to check out if you've recently installed a radio. Otherwise check all the other current-carrying wires in and around the radio area. I'm betting it's around there. </TD></TR></TABLE>
ive had that happen too, i depinned that wire
yea its either the illumination wire on the radio harness or another wire in my center console. it all makes sense now. i knew something was grounding out, but didnt know where at. thanks everyone for your input. if i get stumped ill be back.
