B18C JDM Type R into a ef9 Install Question???
well the motor is in and i have a couple questions ....
1- will my stock throttle cable be fine if i custom make a bracket ..if so can i see pics? Or would i have to get a integra(DA) 90-91 throttle cable ..?
2- i have ngk bkr7e spark plugs, what do they need to be gapped to??
3- what size alternator belt do i need , im using a unorthodox crank pully and stock alternator that came with engine ...
4- is there any clearance from the valve cover and hood>>?? or should i do the vent mode...
any help would be appreciated ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wunPOINTeight »</TD></TR><TR><TD CLASS="quote">well the motor is in and i have a couple questions ....
#1 I don't know, but I think that the Si (EF that is) cable will work.
#2 they come pre gapped don't mess with them
#3 should be the same as original, but again I'm not sure on this one
#4 The vent mode? no get the right engine mounts and be done with it
What are you doing for an ECU?
What axles are you using?
Who's mounts did you use?
</TD></TR></TABLE>#1 I don't know, but I think that the Si (EF that is) cable will work.
jayrdee
Dec 11, 2012 05:35 AM
SuicideSlide
Aug 7, 2004 09:12 AM
akirab16
Jun 26, 2004 04:47 AM
