car boggs out at 4k
alright i was doing an mpfi swap but then after i was done the car wouldnt start for **** so i decided to go get a harness and just put it back to normal and just have someone do it like proffessionally but now it wont even go past 4k no mater wat there are no vaccum leaks cuz ive looked for like 2 days now and couldnt find n e thing missing and now im all out of ideas so im asking you guys..ne help is appriciated...i know im a jackass for trying to do this when im just bassically a begginer but yea my fault...lol thnx ahead of time
forgot to mention that it is throwing a code 1 and four i means oxygen sensor right? and also a number 4 which is crank positoning sensor wat is that and like where is it at on my 1991 crx and can that be the reason it boggs out or wat
its your crank sensor, had the same problem you have either do not have the all the way in the pins, or you have the backwards....switch them and see what happens,
if you have a DMM check the wires....
lilgreenman
Jun 17, 2003 04:40 PM
