HOW TO STROKE A B16? or any bseries at that....
What Up Honda Tech!! I Love this site, who else is with me?
Today I want to talk about how to stroke a motor. I want to know if the guy who built my B16 ripped me off. He says that he put storker rods into my block with some high compression pistons. The new rods and pistons are in my block... but heres the question, " CAN YOU USE JUST STROKED RODS WITH A STOCK CRANK TO STROKE A MOTOR ?" or "IS THERE A CHEAPER WAY TO USE OTHER READILY AVAILABLE SIZE RODS AND CRANK TO STROKE A B16? any stock cranks such as b18 b20?
Today I want to talk about how to stroke a motor. I want to know if the guy who built my B16 ripped me off. He says that he put STROKER<U></U> rods into my block with some high compression pistons. The new rods and pistons are in my block... but heres the question, " CAN YOU USE JUST STROKED RODS WITH A STOCK CRANK TO STROKE A MOTOR ?" or "IS THERE A CHEAPER WAY TO USE OTHER READILY AVAILABLE SIZE RODS AND CRANK TO STROKE A B16? any stock cranks such as b18 b20?
you stroke a motor by using a bigger crank.
this will increase your displacement.
there is not such think as stroke rods.
for example:
a b16 has a 77mm crank.
you can stroke it with the ls crank which is 89mm, but you will need custom rods.
for example:
h22guy
Sep 18, 2018 04:25 PM
