Swapping OBD1 B16 into Del Sol SI
Old Sep 22, 2006 | 07:27 PM
93eg2james's Avatar
Default Swapping OBD1 B16 into Del Sol SI
Alright, I might be getting a Samba Green Del Sol tomarrow. The motor is in good condition, but I want to swap it with a b16 with less milage.
The car is a '94 Del Sol, so its obdI. Its an SI so its wired for vtec also. so would putting an obd1 b16 in this be basicly plug and play?
Old Sep 22, 2006 | 07:34 PM
93eg2james's Avatar
anyone?
Old Sep 22, 2006 | 08:23 PM
93eg2james's Avatar
ttt. need help
Old Sep 22, 2006 | 08:27 PM
BlueIntegraBoy's Avatar
Default Re: Swapping OBD1 B16 into Del Sol SI (97gsrjames)
Yes, it's pretty much plug and play, except you'll need to wire up the knock sensor.
Old Sep 22, 2006 | 08:43 PM
93eg2james's Avatar
isnt the knock sensor alreadt wired?
its already and si (vtec), and both obd1...?
also. will all my mounts work with this? i know i need del sol vtec shift linkage and axels... idk about mounts though
Old Sep 22, 2006 | 09:45 PM
93eg2james's Avatar
Old Sep 22, 2006 | 10:13 PM
dpaton's Avatar
Default Re: (97gsrjames)
It's VTEC, but without a knock sensor, since the Si had a SOHC VTEC motor (A D16 to be specific, which does't use a knock sensor). Your B16 motor needs one, so you'll have to wire it up yourself. The rest of the VTEC system (VTEC solenoid and oil pressure switch) is already there.
Old Sep 23, 2006 | 04:44 PM
93eg2james's Avatar
alright cool. what about mounts? are the stock del sol si mounts good or will i need somehing different.
i heard that i need a b16 rear engine mount? true or false?
Old Sep 23, 2006 | 05:31 PM
You can get all the mounts from an Integra. You'll need a Del Sol VTEC (B16A3) shift linkage.
Chyno
14
Oct 15, 2007 09:34 AM
jd2dub07
Sep 23, 2007 08:59 AM
89civicb16a1
May 20, 2006 09:50 PM
DC2tuner
26
Oct 16, 2004 10:48 PM
91ReXSI
Dec 21, 2001 12:13 PM
