Swapping OBD1 B16 into Del Sol SI
Alright, I might be getting a Samba Green Del Sol tomarrow. The motor is in good condition, but I want to swap it with a b16 with less milage.
The car is a '94 Del Sol, so its obdI. Its an SI so its wired for vtec also. so would putting an obd1 b16 in this be basicly plug and play?
isnt the knock sensor alreadt wired?
its already and si (vtec), and both obd1...?
also. will all my mounts work with this? i know i need del sol vtec shift linkage and axels... idk about mounts though
Re: (97gsrjames)
It's VTEC, but without a knock sensor, since the Si had a SOHC VTEC motor (A D16 to be specific, which does't use a knock sensor). Your B16 motor needs one, so you'll have to wire it up yourself. The rest of the VTEC system (VTEC solenoid and oil pressure switch) is already there.
alright cool. what about mounts? are the stock del sol si mounts good or will i need somehing different.
i heard that i need a b16 rear engine mount? true or false?
jd2dub07
09-23-2007 08:59 AM
89civicb16a1
05-20-2006 09:50 PM
91ReXSI
12-21-2001 12:13 PM
