'03 Accord LX/Front Brake Rotor Removal
Old Sep 22, 2006 | 06:26 PM
RAYThOM's Avatar
Default '03 Accord LX/Front Brake Rotor Removal
I wanted to replace the rotors (and pads) on a neighbor's car. I remove the calipers and "cradle" that holds the calipers and surrounds the disc. So I pull on the rotor and it doesn't budge. I then bang on the center hub with a 2 1/2 lb. hammer. But it doesn't seem to give. I suspect it's probably rusted stuck on the axle and I didn't know just how hard I might need to smack the rotor hub with out damaging anything.
Is there any clips holding the rotor on the axle that I can't see or am I just not whacking the rotor hard enough to dislodge it? I called it quits for the night and thought I'd try again tomorrow maybe with some good advice. What do you know? Thanks.
Ray
Old Sep 22, 2006 | 07:22 PM
Miracle's Avatar
Default Re: '03 Accord LX/Front Brake Rotor Removal (RAYThOM)
Did you pull the little screws out that hold the rotor to the hub? They are #18 in the diagram, and there are 4 of them.
Old Sep 22, 2006 | 11:10 PM
iam7head's Avatar
Default Re: '03 Accord LX/Front Brake Rotor Removal (.Red.EM2)
just the countersunk screw, the bracket and caliper shouldn't be in the way.
most of the time is that it's seized on, a big **** puller will do the trick
bryan0
Mar 25, 2014 10:57 PM
Charlie Moua
Jul 1, 2013 10:04 AM
accord_si
Jul 31, 2006 06:20 AM
1998hondaaccord
Mar 14, 2004 05:57 AM
integra7
Dec 4, 2001 12:41 PM
