...:::92-95 Civic Brakes into EK:::...just checking if i have the right parts!
Old Sep 22, 2006 | 05:56 PM
ExCon's Avatar
Default ...:::92-95 Civic Brakes into EK:::...just checking if i have the right parts!
my parts list is anything off and Eg Si, my friend bought a doner for his Si, he need some engine parts and such but he left the brakes untouched so can i just swap out the prop,valve and Ebrake cable into my ek??? i found a thread but the pics on it werent working so i dont know what i need!
Old Sep 22, 2006 | 05:59 PM
YodajdmEK4's Avatar
Default Re: ...:::92-95 Civic Brakes into EK:::...just checking if i have the right parts! (NOjdmHERE)
Why are you swapping the brake parts in the first place?
Old Sep 22, 2006 | 06:07 PM
ExCon's Avatar
Default Re: ...:::92-95 Civic Brakes into EK:::...just checking if i have the right parts! (YodajdmEK4)
rear discs for my drums is what im doing!
Old Sep 22, 2006 | 06:09 PM
EL Vap133's Avatar
You don't need the prop valve.
Old Sep 22, 2006 | 06:13 PM
ExCon's Avatar
Default Re: ...:::92-95 Civic Brakes into EK:::...just checking if i have the right parts! (EL Vap133)
so i just need the Ebrake cable, trailing arm assembly and thats it???
Old Sep 22, 2006 | 06:18 PM
ExCon's Avatar
ttt
Old Sep 22, 2006 | 06:21 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOjdmHERE &raquo;</TD></TR><TR><TD CLASS="quote">so i just need the Ebrake cable, trailing arm assembly and thats it???</TD></TR></TABLE>
Yes sir, and the brake lines from the Si. When I put in rear discs into my 97 Civic DX, I used my stock prop valve and the car still stops on a dime with NO problems.
Old Sep 22, 2006 | 06:25 PM
ExCon's Avatar
cool thnx for the help
trailing arm ***.
ebrake cable
brake lines
and some brake fluid. and ill have myself rear discs right i just what to make sure thats all because this is my daily driver and i need to get to work plus i dont get to days off back to back!
Old Sep 22, 2006 | 08:28 PM
DOHCtorTHRUST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOjdmHERE &raquo;</TD></TR><TR><TD CLASS="quote">cool thnx for the help
trailing arm ***.
ebrake cable
brake lines
and some brake fluid. and ill have myself rear discs right i just what to make sure thats all because this is my daily driver and i need to get to work plus i dont get to days off back to back! </TD></TR></TABLE>
thats it
'96-EJ6Hatch
32
Mar 18, 2012 05:21 PM
turboblack2door
Apr 30, 2009 03:18 PM
Turbo Dan
Aug 8, 2006 07:05 AM
em2ssm02
Jul 15, 2006 08:09 PM
Turbo Dan
Oct 30, 2005 12:56 PM
