Comp Ratio
Old Sep 22, 2006 | 05:55 PM
vtec-gorilla's Avatar
Default Comp Ratio
whats a good comprosion ratio to have for an all motor set up? is an 11.8.1 ratio to high?
Old Sep 22, 2006 | 09:46 PM
B18 CYA's Avatar
no thats pretty good. id say anywhere near 12:1 is good for street.
i am running 13.5:1's in my motor right now on 94 pump. soon to be 110 tho
Old Sep 23, 2006 | 09:20 AM
Default Re: (B18 CYA)
could a to high comp ratio hurt my motor cause i plan on shooting a 50 shot?
Old Sep 23, 2006 | 01:49 PM
crawlin's Avatar
Default Re: (vtec-gorilla)
high compression isnt really to reasonable for the street when you can only run 92-94 octane itll just hurt you the higher you go, enless you plan on gettting some 55 barrel drums of 110 at that **** will get expensive
11.5-12.5 is usually a pretty good setup
Old Sep 23, 2006 | 01:52 PM
The_Head's Avatar
Default Re: (crawlin)
That's what I'm going to be doing, buying a drum of race gas and mixing it 4:1 with 91, to give me around a 95 octane rating. My Civic is not designed to be a daily driver though, so I won't be using alot of race gas.
Old Sep 23, 2006 | 07:04 PM
Default Re: (The_Head)
with this type of comp ratio i shouldn't have to worry about hitting the pistions right? valve to pistion clearence should be good ?
RichD14
Oct 30, 2016 09:43 AM
cardudelude
Sep 3, 2009 11:11 AM
DJ_NeX
29
Sep 8, 2006 05:30 AM
norcalbayboy
29
Aug 7, 2006 10:08 PM
