Check engine light after msd ss coil install
Old Sep 22, 2006 | 01:23 PM
es_squared's Avatar
Default Check engine light after msd ss coil install
yo guys, i just installed my msd ss coil by itself, no ignition box, and the check engine light comes on after probly 2 or 3 mins of driving.. and stays on. if i turn the car off and turn it back on, same thing.
Old Sep 22, 2006 | 01:24 PM
BB2H22's Avatar
Default Re: Check engine light after msd ss coil install (es_squared)
Did you check the code its throwing?
Old Sep 22, 2006 | 01:25 PM
es_squared's Avatar
Default Re: Check engine light after msd ss coil install (BB2H22)
no i don tknow how to check codes
Old Sep 22, 2006 | 01:53 PM
es_squared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared &raquo;</TD></TR><TR><TD CLASS="quote">no i don tknow how to check codes </TD></TR></TABLE>
k i did a search and found out where the service connector is (behind the radio, driver side) but i cannot for the life of me find it ! i can see the 3p connector but not the 2p
Old Sep 22, 2006 | 02:00 PM
K-Spec's Avatar
check the passenger side center console...to the right of the radio...
Old Sep 22, 2006 | 03:21 PM
es_squared's Avatar
Default Re: Check engine light after msd ss coil install (khalal538)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">check the passenger side center console...to the right of the radio...</TD></TR></TABLE>
checked. nopthing. fuckign pissing me off
Old Sep 22, 2006 | 03:43 PM
K-Spec's Avatar
what happened to your stock coil?
Old Sep 22, 2006 | 03:54 PM
es_squared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">what happened to your stock coil?</TD></TR></TABLE>
nothing, got a good deal for the msd coil
Old Sep 23, 2006 | 09:27 AM
es_squared's Avatar
up
Old Sep 23, 2006 | 11:27 AM
DIRTYsouthBB6's Avatar
The reason that you don't see it is because it is underneath a small carpeted panel that snaps on and off. Look on the passenger's side of the center console, and you will eventually find a place where the carpet isn't flush. Snap that panel off and the service port is under it.
Old Sep 23, 2006 | 11:28 AM
mgags7's Avatar
hes got a 4g lude, unless his avatar is misleading
the plug has two wires going to it, it is clipped into a connector that just pops in and holds it down there, the wires dont go anywhere else....
Old Sep 23, 2006 | 11:29 AM
es_squared's Avatar
Default Re: Check engine light after msd ss coil install (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">The reason that you don't see it is because it is underneath a small carpeted panel that snaps on and off. Look on the passenger's side of the center console, and you will eventually find a place where the carpet isn't flush. Snap that panel off and the service port is under it.</TD></TR></TABLE>
aaah alright, thanks for that ill check for it again when i got time an dpost up the code
Old Sep 24, 2006 | 11:44 AM
es_squared's Avatar
ALRIGHT i got the code and found the connector finaly lol !
anyway. the engine light would flash like this.
1 Long
2 Short
and keep doing that.
Old Sep 24, 2006 | 11:48 AM
es_squared's Avatar
did a search and looks like i got a code 12 : EGR valve llift sensor. i don thtink this is related to the msd.. any ideas?
Old Sep 24, 2006 | 01:22 PM
es_squared's Avatar
alright found the issue. my stupidity lol
tempsohc
Jul 4, 2016 08:30 AM
osuperjohno
Jul 28, 2005 08:17 AM
sal_blkej2
May 7, 2004 09:54 AM
ErikDaGenErik
Nov 10, 2003 04:57 PM
integrater
May 7, 2003 11:52 AM
