removing headlights?
is it the entire headlight aseembly? if so then you have to remove the front bumper , its easy start by removing the front fenders drivesrs n passangers then open hood and start removeing snap on's then you should be able to snap off the bumper , once snaped off just remove headlight screws , take off old 1 put new 1 , i did not unplug my battery ,
ADDED: YOU NEED TO REACH THE BACK OF HEADLIGHT hence why i removed mine... but stick your hand in and turn it 1 way and it should be loose then plug the new ballast set
Modified by gus738 at 10:51 PM 9/22/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buffcop8 »</TD></TR><TR><TD CLASS="quote">was anyone able to change their bulbs with out removing the headlights?</TD></TR></TABLE>
well bulbs yes however hid kit alot of parts need to be run and mounted... so no
i installed mine. never took off the bumper, you need small hands!! on the right side youll have to take off the resevoir of coolant...i have an lx if you have a si it might be different.
dom93hatch
Feb 20, 2008 01:45 PM
