1997 prelude questions
Old Sep 22, 2006 | 11:08 AM
EFhothatch15's Avatar
Default 1997 prelude questions need HELP
ok i just bought a 1997 prelude sh with 152k mile seem to be going good until the check engine light came on and flashed and the car started to stumble a little so i pulled over and the car was knocking the knock is only at idle and goes away when i rev the engine. I checked the compression of the cylinders it was 150, 150, 150, 145. i need help figuring out whats wrong with it.
Modified by EFhothatch15 at 6:27 PM 9/22/2006
Old Sep 22, 2006 | 11:33 AM
Revi's Avatar
Default Re: 1997 prelude questions (EFhothatch15)
Well to start your compression is low. Since its pretty consistant i would guess those piston rings are worn out. I dont know the history to determine if it could have bent valves, but you should have a shop do a leak down test also.
Did you check what code the car threw out? It could be a malfuctioning knock sensor.
Old Sep 22, 2006 | 12:10 PM
Chuckles99SH's Avatar
Default Re: 1997 prelude questions (Revi-Ra)
That could be the compression tester reading low, or timing off. Best thing is that all the numbers are close together. Until you pull the CEL code you wont know the problem.
Old Sep 22, 2006 | 12:12 PM
i didnt rune the code i unplugged the batterie and it reset and hasnt came back on, the knock sensor was replaced by previous owner. thanks for the help
Old Sep 22, 2006 | 04:52 PM
prelude1897's Avatar
Default Re: 1997 prelude questions need HELP (EFhothatch15)
might wanna do some of the regular maintence work such as valve adjustment, oil change, tranny fluid change, radiator fluid change, cap, rotor, plugs, ect.
Old Sep 23, 2006 | 10:22 AM
thanks for the help so far, anyone else have any ideas
Brett1329
Feb 17, 2017 11:16 AM
CAN97SH
Jul 14, 2011 05:29 AM
trey033
Jun 1, 2009 11:51 AM
clamas13
Oct 12, 2007 07:54 AM
AntonioH
Aug 1, 2005 09:52 AM
