melted cat
just wondering if anyone else here has melted ther cat converter due to the stock ecu running hell rich in the upper rpms
just yesterday my cat converter **** itself. last time i was on the dyno af ratio was in the 10's, that was with intake, since then have added header and exhaust 2 1/2"
i know its my fault but funds were not there to buy power fc and gears
later
later
good lord! 10:1??!?!?!? What you need to do is in to invest in these 3 things..maybe..Of course this is all opinion...everyone has their own preference on what to buy...
1. fuel pressure gauge ~$20 US Dollars
2. fuel pressure regulator ~$80-120 US Dollars for a decent one..(none of that bling&m crapola)
3. a/f gauge ~$100-250 (again...for a decent one..no Autometer junk) I recommend a Defi gauge (which I have and love) or the more expensive Greddy a/f gauge which comes with its own o2 sensor.
I honestly don't know how the heck your stock ecu could be running so rich I'm running 3psi over stock right now and I'm reading around a 14.5:1 for partial throttle cruising, between a 14.0:1 to 13.8:1 for WOT in every gear depending on RPM. My car seems to be happy with a 13.7ish ratio...
btw...I like the defi and greddy gauges because those gauges read an actual number..unlike the Autometer which just show colored bars that tell you that you're rich/stoich/lean
beats me how rich it is
like i said when i was on the dyno last, b4 header/exhuast, the intake made about 5 hp up until vtec, but after it just went rich as and ended up losing 10hp up top.
i have desposit down for fc and gears and should have them soon, exhuast place http://www.exhaustdynamics.com.au said i was lucky the cat lasted the some 7000km that it did
are well
more money to be spent
in regards to u, how dont u ping if your af ratio is 14's with usa shitty fuel, unless u have a standalone and have tuned the ignition
are well
14 isn't that bad...if I was running 15+ then I'd be worried... btw..I'm running a ctr ecu in my 2000 Si. Stock fuel pressure is 43psi w/ vacuum off...I'm running 46..thinking about doing 48...
