Torque Wrench Issue, dialing in below lowest setting tick mark
Old Sep 22, 2006 | 08:06 AM
Dangger's Avatar
Default Torque Wrench Issue, dialing in below lowest setting tick mark
I'm was doing to head work and the the torque specs for the cam shaft holders at around 7-9 ft-lbs
My big craftsman torque wrench has the lowest setting at 20 ft-lbs. I'm able to turn the the dial past the lowest tickmark and guess at where the 7ftlbs should be. Is this is an accurate setting? or am I way beyond the threshold of the wrench?
the 7 ftlb setting compared to the 9 ftlb setting seems kinda the same... and it's kinda weak, I'm just worried since it's for headwork.
Old Sep 22, 2006 | 08:28 AM
The Destroyer's Avatar
Default Re: Torque Wrench Issue, dialing in below lowest setting tick mark (Dangger)
You sure its not inch-lbs?
Old Sep 22, 2006 | 08:34 AM
RDub's Avatar
I'd get the proper torque wrench to do the job
Old Sep 22, 2006 | 09:37 AM
Dangger's Avatar
well... i'm able to use either Newton Meters or Foot Pounds on my torque wrench. The Helms Book gives it to you in both settings.
it's only a matter of units, so it should be the same. I'm just worried about not having the correct torque because my wrench don't have the tick marks go as low.
Old Sep 22, 2006 | 11:31 AM
spoonek9's Avatar
Default Re: (Dangger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dangger &raquo;</TD></TR><TR><TD CLASS="quote"> I'm just worried about not having the correct torque because my wrench don't have the tick marks go as low.</TD></TR></TABLE>
The marks don't go that low for a reason! Use a different torque wrench.
Old Sep 22, 2006 | 11:32 AM
mgags7's Avatar
Default Re: (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">The marks don't go that low for a reason! Use a different torque wrench. </TD></TR></TABLE>
lol really....get an inch/lbs wrench, big ft-lb wrenches aren't accurate down there....
Old Sep 22, 2006 | 05:00 PM
NJIN BUILDR's Avatar
Torque wrenches are most accurate in the middle of there range.You really need a couple torque wrenches to work on Hondas.
Old Sep 22, 2006 | 05:41 PM
JCushing's Avatar
Default Re: Torque Wrench Issue, dialing in below lowest setting tick mark (NJIN BUILDR)
you are not supposed to use the upper and lower 20 percent of the indicated range let alone go below the range.
just go to sears, buy the one you need then return it lol
smxcan
Jan 12, 2009 07:17 PM
b20vtech
Apr 1, 2008 03:07 PM
komat
16
Jun 2, 2005 08:14 PM
