another b18b swap question
Old Sep 22, 2006 | 07:57 AM
HFpower's Avatar
Default another b18b swap question
my friend just gave me his motor which is a b18b
what do u need to put this in my car.
can someone please make me a list
that all i can come up with
im gonna be use a b16 S1 cable tranny
1 mounts
2shift linkage
3DA knuckles
40d0-odo 1 dizzy
590-93 integ axels
6?
7?
8?
Modified by HFpower at 9:09 AM 9/22/2006
Old Sep 22, 2006 | 08:06 AM
crxnj's Avatar
Default Re: another b18b swap question (HFpower)
mounts,linkage,obd1 pr4,convert your car to obd1,knuckles arent needed unless you have an hf/std which i assume you do from your name,use 94 integra axles,cause i couldnt get a 90 integra halfshaft to bolt to the b18b engine,,so use 94 integra halfshaft/axles..if you get a cable tranny then you gotta get new axle seal for the hydro axle....if you get a hydro tranny you gotta get mounts for the hydro tranny,,unless you plan on running the complete hydro system..Thats the basic stuff theres other small things
Old Sep 22, 2006 | 08:13 AM
Loserkidwac's Avatar
Default Re: another b18b swap question (Mr.speaker)
I have a 90-93 Mid shaft on a B18b with a cable trans, more than likely you had a auto midshaft they are a tad bit shorter i believe than the manual trans mid shafts...look in the FAQ section there should be a good list of what you need, I'd suggest staying OBD0
Old Sep 22, 2006 | 08:30 AM
crxnj's Avatar
Default Re: another b18b swap question (Loserkidwac)
yeah i dont know why it wouldnt work,,but the 90 teg halfshaf i had just would bolt to a 97 ls block when putting it in someones car,
Old Sep 22, 2006 | 12:31 PM
HFpower's Avatar
thank guys with all the info
Old Sep 23, 2006 | 12:00 AM
HFpower's Avatar
is that all
EG6Boy702
Apr 29, 2009 07:56 PM
kixcrx
Jan 15, 2007 08:43 PM
n2oef
Jul 30, 2006 12:42 PM
Tru Dynamix
Jan 2, 2003 07:22 PM
