S2k cluster into eg
yes but unless your some wiring guru the speedo is gunna be horribly off and other things will not work there was one person on here that god it to work but the speedo was still off i believe. the problem is, is changing the analog dials to digital for the s2k cluster im sure theres more people on here that know more about it then me im just tellin ya what i know
Someone sells a box to convert your vss signal to be displayed correctly on an s2k cluster. I beleive it's adjustable too. I don't feel like searching around for it, but I read the thread that linked it not too long ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp »</TD></TR><TR><TD CLASS="quote">Someone sells a box to convert your vss signal to be displayed correctly on an s2k cluster. I beleive it's adjustable too. I don't feel like searching around for it, but I read the thread that linked it not too long ago.</TD></TR></TABLE>
really in for more info on this
Go here for the converter...
http://www.dscustoms.com/s2kpa...e.htm
And you'll also need a coolant temperature sensor converter that converts your analog signal to the digital signal that the s2k cluster requires. Good thing though, because here is the link to that converter...
http://www.dscustoms.com/s2kpages/ect.htm
After its all said and done, you're looking at the cluster ($200) + signal converter ($170) + ect converter ($70) = $440 cluster...and thats not including whatever other problems you might run in to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gunslinger89 »</TD></TR><TR><TD CLASS="quote">DONT EVEN TRY IT lol but if you do get pics</TD></TR></TABLE>
I was going to do it, but I have no money...
Sounds like a fun project.
93EG6SI
Jan 18, 2007 08:09 AM
BubLBack
12
Sep 7, 2006 09:23 PM
