98 GSR Seat bracket into an EJ8 Question:
Old 09-22-2006, 03:35 PM
grammer nawzi
sicky's Avatar
Default 98 GSR Seat bracket into an EJ8 Question:
Just curious if the brackets from a 98 GSR will bolt directly unto the EJ8 chassis. If there are slight modifications that need to happen any info would be appreciated.
Reason for question: Might pick up 98 GSR leather front seats and curious if the seats can bolt directly into my 97 EX coupe. Don't have my rails (brackets) any longer, sold a while ago.
Old 09-22-2006, 03:41 PM
BlueIntegraBoy's Avatar
Default Re: 98 GSR Seat bracket into an EJ8 Question: (sicky)
Same concept.
https://honda-tech.com/zerothread/958044
Old 09-22-2006, 03:49 PM
grammer nawzi
sicky's Avatar
Default Re: 98 GSR Seat bracket into an EJ8 Question: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Same concept.
https://honda-tech.com/zerothread/958044</TD></TR></TABLE>
I understand that, but as I stated in my first post I no longer have my stock rails/brackets. Therefore I am curious if the brackets off of the 98 GSR will bolt right into my chassis.
Unsure if what you linked is directly saying "Yes those brackets from the GSR will bolt right into the same spot as the EJ8 brackets" or not.
Old 09-22-2006, 03:57 PM
No, it won't. You can only bolt up 3 bolts. The procedure from above tells you how to swap rails. You can go to a junkyard and pick up cheap EK seats.
Old 09-22-2006, 04:12 PM
jdmeg6drifter's Avatar
it will line up only 3 holes but it will be fine i hsve been doing it for over a year now and no probs. I got mine out of a 4dr gsr and the front and back fits perfectly with no gap
P0411
04-24-2019 01:57 PM
integra_jdm_08
01-29-2008 03:57 AM
Evolution-93-Ex
08-23-2007 05:28 PM
TurboLSVtecTeg
06-07-2004 11:01 AM
Quick Reply: 98 GSR Seat bracket into an EJ8 Question:
