Hey guys..new to this..
Old Sep 22, 2006 | 02:01 AM
Aetsh's Avatar
Default Hey guys..new to this..
I have a few questions..First off I have a 88 Civic DX which I plan on making a reliable, but fun daily driver. First question is..I need a clutch, BAD. Would one of the $100 kits from ebay do the trick? Also, how difficult is the install, and what would be involved?
Second, I want to buy this short shift kit
http://cgi.ebay.com/ebaymotors...ZWDVW
and I was curious to how easy/hard it is to put in, and how long it might take?
I appriciate all the help, Thanks in advance!
Old Sep 22, 2006 | 02:06 AM
CRXDaddy78155's Avatar
Default Re: Hey guys..new to this.. (Aetsh)
Good questions...I don't know a whole lot about clutches but wondered the same things.
Old Sep 22, 2006 | 02:24 AM
RexQ's Avatar
Default Re: Hey guys..new to this.. (88DXREX)
yes get the exedy kit from ebay, great clutch. install isnt that bad just need a lot of man power and a couple good jacks. air tools would be an extreme plus but isnt exactly neccessary
for the short shifter put in a couple more bucks and get a good one, B&M, they're like 25-30 bucks or mine was. the cheaper ones are known to break. install is easy, do it while changing your clutch, i suggest getting new bushing while you're at that too
Old Sep 22, 2006 | 02:33 AM
Aetsh's Avatar
Thanks guys..Can I do the short shift kit before/after I do the clutch? and what bushing am I wanting to buy?
Also, does the ebay kit have everything I need..someone told me to do the throw out bearing while I was in there..anything else I should do when I'm in the trans?
Old Sep 22, 2006 | 02:54 AM
crxnj's Avatar
i reccomend this clutch kit,comes with everything,and you say you want alittle fun so get a stage1.its not crazy but it does feel better then stock..http://cgi.ebay.com/ebaymotors...ZWDVW comes with clutch disc,pressureplate,throwoutbearing,pilot bushing and alignment tool,,and this is not some piece of garbage clutch,ive installed so many of these things
for actually replacing it its not hard at all..all you need is tq wrencch,ratchet,sockets,normal tools,jack+block of wood,cheater bar,it would really help if you have a 2nd man..and of course a workshop manual for the tq specs and all the directions..and since you're going to do a shortshifter install you might as well just drop the tranny + linkage as 1 whole unit,,and now you dont have to worry about the bitch pin,etc.and get some new shifter bushings,,i use energy suspension bushings and the shifting is tight.
Old Sep 22, 2006 | 01:03 PM
LatnKng's Avatar
Its fairly easy to put in, but one thing u must be sure of....you gotta make sure that you get the right year clutch and pressure plate because some splines might not line up, as long as u got the right year plate and clutch u good. I just changed a clutch in an 88 rex dx, and the clutch was the right year but the plate that came with it was the wrong one, and vise versa, so i had to go with a 89 plate and 88 clutch. It takes about 2 hours if done correctly. ENJOY, IT SHOULD BE FUN. U CAN DO IT.
Old Sep 24, 2006 | 09:54 AM
Default Re: Hey guys..new to this.. (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">want alittle fun so get a stage1.its not crazy but it does feel better then stock
When you say "Feel Better than a Stock" how much different than a stock, is the clutch you listed on ebay?
Old Sep 24, 2006 | 10:11 AM
89 civic si's Avatar
i have a exedy clutch in my prelude and it has been going strong for20 k now so yeah...the hardest thing to do in my opinion is put the trans back on the motor..oh yeah and the shifter linkage pin which i am currently fighting with after my d15 vtec swap
Old Sep 25, 2006 | 06:58 PM
LatnKng's Avatar
Default Re: (Aetsh)
make sure that the throw out bearing spring hooks are connected properly and that the bearing comes out all the way or extends out completely.
DenzComp
26
Apr 19, 2007 05:28 PM
lsegcoupe
22
Feb 27, 2006 10:08 PM
getdrugtoday
Nov 7, 2004 11:09 AM
LsV
Jul 3, 2004 12:41 PM
PEARLWHITE
Jan 20, 2003 01:20 PM
