car caught fire
Old Sep 21, 2006 | 10:52 PM
unbelievableEG's Avatar
Default car caught fire
So I was driving home from work and i smelt a electrial burning smell i looked over to my passenger seat and saw smoke coming from in-behind my glove box. I immedallity pulled over and riped off my glove box (breaking it) so see smoke but nothing burning.
So I let it go away Figure okay lets keep driving. Five minutes later I smell it again and notice the smoke again. Finally I pulled into a gas station and poped my hood and saw my passenger side headlight plug was completlty melted and all the wiring was slowly burning up into my firewall and in-behind my dash board. I start taking off the covers over the wiring trying to see how far expoised wire is.
I rip apart all the wires that melted together and taped everythin up. Once i was finished I started my car ran fine, i turn on my corners and fogs still running fine. I turn on my headlights and my car dies. (at this point i only have the driver light hooked up and the passenger side plugs i cut off). So I pull my key out of the ignition and wait a few secounds and turn the car back on again runs fine untill i turn on my headlights. So im like scream it its 2am i'll deal with it in the morning.
I'm driving along and im like ill try my headlight again. again as soon as i switch them on it immdelity turns the car off as if i pulled the batterie out of it.
Now I have no idea what this is being cuased by im going to re-wire my headlight tomorrow and hope that that fixes the car from shutting off when i turn on my headlights.
If anyone knows what this could be please let me know ASAP!
(I'll take pictures of everything tomorrow)
Thanks.
turbociviccoupe's Avatar
Default Re: car caught fire (unbelievableEG)
pics
Old Sep 22, 2006 | 06:49 AM
perseverance's Avatar
sounds like something was grounding out and there was no fuse. was there any previous ghetto rigging to ur lights?
Old Sep 22, 2006 | 07:44 AM
fventura03's Avatar
have you done any mods to your wiring?
if not, something most likely rubbed against a wire, and is causing the negative and positive wires to touch...
Old Sep 22, 2006 | 07:53 AM
92redhatch's Avatar
Sounds like you put a bigger fuse in some place then you should have. When there is a short like that it will normally blow the fuse and wont catch fire. I know for a fact that you have a higher amp fuse somewhere then your supposed to use. I know this because on day i saw i kept blowing fuses and me being retarded i put a 30 amp fuse (instead of a 15) and i ran into the same problem.
Old Sep 22, 2006 | 08:35 AM
Luserkid's Avatar
Default Re: (92redhatch)
Did you have those aftermarket lights? There known for doing that.
Old Sep 22, 2006 | 10:51 AM
when I had HIDs I had to change the fuse to 30 both left and right and i never changed them when I took my HIDs out.
Old Sep 22, 2006 | 10:52 AM
HondaEJ7's Avatar
u didnt get water in on the wiring or anything did u?
Old Sep 22, 2006 | 03:34 PM
nope no water... ive started wiring everything back together i just have to find what wire is grounding and taking all the power when i turn on my headlights
Old Sep 22, 2006 | 07:24 PM
plz turn off trial user's Avatar
Default Re: (unbelievableEG)
u know hwne u pull u battery out ur car does not die right?, it runs off alternator power completly, we do that at work whenever we need to pull the battery for a convience to the customers..............
Old Sep 22, 2006 | 07:31 PM
dthug's Avatar
Default Re: (spork motorsports)
soundsl ike a great killswitch to have, at night theives would think they have your car, turn on the lights can BAM shuts off
sorry for the useless post but i had to say it, gl hope you fix it!
Old Sep 23, 2006 | 01:31 AM
Default Re: (dthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug &raquo;</TD></TR><TR><TD CLASS="quote">soundsl ike a great killswitch to have, at night theives would think they have your car, turn on the lights can BAM shuts off
sorry for the useless post but i had to say it, gl hope you fix it!</TD></TR></TABLE>
haha that'd be great!. Well i started re-wiring and turns out the warness melted together further inside so in the morning im pulling my dash out and going to the junk yard to find another harness.
also now when i turn my key to ON where the fuel pump turns on then off, well my fuel pump stays on now... so hopfully when i pull the dash and change the wiring it'll all go back to normal
Old Sep 23, 2006 | 07:26 PM
92redhatch's Avatar
if you had the right fuse it wouldn't have burn't your wires. You have a short circuit somewhere in your car. And when you replace the harness make sure to use the right fuse!
Old Sep 23, 2006 | 07:37 PM
Rodzknight's Avatar
great idea pulling into a gas station when you thought your car was on fire.
anywayz.........you got a big problem with wiring right now and untill you replace almost everything (b/c you dont really know where the problem is) you will have one problem right after the other. good luck.
Old Sep 23, 2006 | 07:55 PM
re-wired everything but now my fuel pump isn't priming it got dark so i left it for the morning
Old Sep 23, 2006 | 09:43 PM
well still the fuel pump wont prime although it worked fine befor i took everything apart.
Tomorrow I will be replacing the main fuse checking all grounds and if nothing happends then im probley just gonna push my car off a cliff
Old Sep 23, 2006 | 10:06 PM
romoracing's Avatar
Check the wiring behind the fuse box. Sounds like the head lights are grounding out and it might be close to the battery ground. Also ive installed a few hid kits and ive NEVER changed the fuse to a bigger one. Reason is fuses are there to protect the..........wire.
Old Sep 23, 2006 | 10:32 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
To me, it sounds like when you had the HID's, you melted a wire or two and now your paying for it. Your going to have to rip the entire harness out of the car if possible. There are probably a ton of burnt wires all the way through the interior harness too. Its a pain and time consuming, but you might as well do it now, or you will probably continue to have electrical issues.
You shouldn't have replaced the fuse's with a higher one... you wouldn't have this problem right now.
Old Sep 23, 2006 | 10:51 PM
the Brightstar kit required me to change them.
The only part of the harness I havent touched yet is from under the batterie into the firewall.
I have re-done all the wiring in side the car but i left about 4 inches then what goes thrrough the firewall into the engine bay. Worst comes to worst ill cut every end and run every single wire again
sageuvagony
56
Oct 2, 2008 07:07 PM
AnDy327
Mar 22, 2008 03:32 PM
0h teh sl0w k20!!
Jan 22, 2006 11:27 AM
Exit Music
Dec 5, 2005 04:20 PM
jdmbb6
Nov 15, 2004 05:34 PM
