diy rear camber fix?
does any one know how to fix the rear camber by buying bolts and washer at the department stores? instead of wasting a lot of money on the real camber kit? i saw it once but i cant seem to find it again. if you have the part numbers that would help a lot, thanks
You can just use washers until it looks like the camber is almost at 0, but it won't be as good as actually using a camber kit and getting an alignment. Otherwise, using washers, it's a trial-and-error process.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">You can just use washers until it looks like the camber is almost at 0, but it won't be as good as actually using a camber kit and getting an alignment. Otherwise, using washers, it's a trial-and-error process.
-Shane</TD></TR></TABLE>
You wouldn't want 0º of camber anways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9child »</TD></TR><TR><TD CLASS="quote">http://home.earthlink.net/~civ....html</TD></TR></TABLE>
There you go...
I don't remember if it says it in the link but, get an alignment and zero out the toe.
There you go...
