which one do i use?
Old Apr 30, 2002 | 06:26 PM
rasta420's Avatar
Default which one do i use?
if i do a d16y8 mini-me head swap into my d16a6, and i use a p28 ECU, which distributor will bolt up to the y8 head and run with the p28 ECU? i know the Si (a6) distributor wont bolt up to the d16z6 head without mods, so would the z6 distributor bolt to the y8 without mods? or do i go with a y8 distributor? but a y8 is OBDII i believe.....
what should i do?
also, would y8 intake manifold and throttle body fit on my mini-me setup? would that result in better performance?
EDIT: since the a6 distributor bolts without problem to a y8 head, that would mean the y8 dist has the same bolt holes as the a6, but because i wanna go p28 ECU, that would mean i need a OBDI dist i believe...but that would mean a z6 dist, but since the z6 dist doesnt bolt to the y8 head without mods, i wanna go with a y8 dist...but i think thats OBDII...
just tryin 2 clarify, ahh HELP!!!!!!
[Modified by rasta420, 3:30 AM 5/1/2002]
Accord9422
Mar 10, 2012 01:51 PM
dohdoh420
23
Oct 20, 2005 05:56 PM
gmcrxsi
Aug 13, 2005 12:27 PM
greddytunedhatch
Feb 7, 2005 04:47 PM
94dxt
Dec 26, 2003 08:49 PM
