whats this? engage clutch and it leaks!!!
Old Sep 21, 2006 | 06:07 PM
BB1_VTEC's Avatar
Default whats this? engage clutch and it leaks!!!
i do not know what this part is called... sits right on top of the tranny right under the lower radiator hose, how would i go about fixing this? is there a seal or just replace it???
Old Sep 21, 2006 | 06:13 PM
mgags7's Avatar
it only leaks when you engage the clutch?? the clutch soft line bolts into a little valve body right there and then goes to a hard line, which goes down to the slave cylinder.....that valve body may be what is leaking
the pictured part is a shifter lever....that should not be leaking anything, as it sits way above the fluid level in the trans....
Old Sep 21, 2006 | 06:17 PM
BB1_VTEC's Avatar
Default Re: (bb4ever)
whenever i get done driving and let it sit for a while thats when i notice the leak.. i also notice my clutch master cylinder gettin low in fluid.. and if it is the valve body how do i fix it? just replace it with another one?
Old Sep 21, 2006 | 06:25 PM
mgags7's Avatar
you probably just need a new banjo bolt and some new washers.....
Old Sep 21, 2006 | 06:56 PM
shutta's Avatar
yeah man, just try tightening that bolt down some more... if it's getting too tight and risking snapping, new bolt/washers
Old Sep 21, 2006 | 07:07 PM
AnthonyG2003
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">you probably just need a new banjo bolt and some new washers.....</TD></TR></TABLE>
Mine did the exact same thing and thats all i did...was just got a new banjo bolt and new washers....tighened it down and then bled the clutch again.
Robert O
Honda S2000
Oct 6, 2010 04:01 PM
big_az
Mar 23, 2009 01:54 AM
us31wking
Jun 30, 2007 02:30 PM
AccordOn18z
Jul 7, 2006 02:57 PM
redeg61987
10
Feb 10, 2006 09:52 AM
