NEED ADVICE!!! SUPER CONFUSED!!
Old Sep 21, 2006 | 05:52 PM
iamhollywood[BRS]'s Avatar
Default NEED ADVICE!!! SUPER CONFUSED!!
so my car has an idle issue. it idles high sometimes and low at other times. its also jerking real bad when getting on/off the throttle. I checked the cel and got a code 7. I tested the tps and its reading .5 idle and 5wot. so my tps seems to be working. I also replaced the map sensor. am I missing something here? should I still replace it? I'm stumped. TIA!
ryan
Old Sep 21, 2006 | 09:26 PM
NA_H22_Ej's Avatar
Default Re: NEED ADVICE!!! SUPER CONFUSED!! (iamhollywood)
see if ur ecu is FRIED... happen to me, the diode or resistor that was reading the TPS signal was messed up bad
Old Sep 21, 2006 | 09:34 PM
turbociviccoupe's Avatar
Default Re: NEED ADVICE!!! SUPER CONFUSED!! (NA_H22_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_H22_Ej &raquo;</TD></TR><TR><TD CLASS="quote">see if ur ecu is FRIED... happen to me, the diode or resistor that was reading the TPS signal was messed up bad</TD></TR></TABLE>
Old Sep 21, 2006 | 09:58 PM
jdmspec1122's Avatar
check ecu
Old Sep 21, 2006 | 10:02 PM
4dohs4mohoes's Avatar
Default Re: (jdmspec1122)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspec1122 &raquo;</TD></TR><TR><TD CLASS="quote">check ecu </TD></TR></TABLE>
Old Sep 21, 2006 | 10:58 PM
I never would have thought about that. how would I go about checking to see if the ecu is the underlying issue here?
Old Sep 21, 2006 | 11:12 PM
Jagolas's Avatar
easiest way = find sumone with same ecu and just borrow for test drive.
lshatch1.8
Jan 8, 2008 12:33 AM
durfeec
11
Aug 25, 2007 09:50 AM
Pete_SI
Mar 22, 2005 03:12 AM
imlachg1
16
May 22, 2004 06:04 PM
hondaeg8
May 6, 2004 06:10 PM
