Rebuilding GSR transmission question(s)...
Old Apr 30, 2002 | 05:42 PM
drumsy's Avatar
New User
Default Rebuilding GSR transmission question(s)...
I've got my transmission apart completely now, and the next step is to clean clean clean with solvent, but I was curiuos, what are ALL of the "consumable" parts that I'll need to replace. Best place to purchase? Do ALL bearings need to be replaced?
Thanks!
Old Apr 30, 2002 | 06:45 PM
IN VTEC's Avatar
Default Re: Rebuilding GSR transmission question(s)... (drumsy)
You don't have a Service Manual, do you?
Old Apr 30, 2002 | 07:25 PM
drumsy's Avatar
New User
Default Re: Rebuilding GSR transmission question(s)... (IN VTEC)
Yes, I do have a Helmes manual. However, I'm not not sure if ALL parts need to be replaced. i.e. I have a one of the needle bearings in where the countershaft sits. I haven't pulled it yet. Does it really need to come out? Does the oil guide plate beneath it need to be replaced? And finally, where is the BEST place to order these parts? Dealership?
Old Apr 30, 2002 | 10:40 PM
Rocket's Avatar
Check condition of your synhros (sharp teeth and sharp ribs on the inside), check all engagement teeth on the gears and sleeves.
You may also want to change the friction dampers. They look like seals.
These parts are expensive though.
SpeedwaySlick
Jan 13, 2007 12:37 PM
Darkestankh
Oct 13, 2006 07:54 AM
EFMAN
Apr 4, 2005 09:24 AM
wutangben
Jun 21, 2003 10:33 PM
mipawi
Mar 15, 2003 09:17 PM
