Burning oil symptoms?
Old Sep 21, 2006 | 02:45 PM
screename's Avatar
Default Burning oil symptoms?
Are there any symptoms of how to tell if your car is burning oil? (car smoking etc.)
My car just recently had an oil change about 1000k ago and its almost to the low mark on the dipstick.
any and all help appreciated thanks.
Old Sep 21, 2006 | 02:47 PM
Brick Top's Avatar
Default Re: Burning oil symptoms? (screename)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screename &raquo;</TD></TR><TR><TD CLASS="quote">Are there any symptoms of how to tell if your car is burning oil? (car smoking etc.)
any and all help appreciated thanks.</TD></TR></TABLE>
what you stated is the most obvious symptom. or its leaking
Old Sep 21, 2006 | 02:52 PM
Syndacate's Avatar
Default Re: Burning oil symptoms? (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">
what you stated is the most obvious symptom. or its leaking</TD></TR></TABLE>
Symptom of heavy burning oil is blue smoke out the tailpipe. I believe it's blue, I do get my colors confused with different problems, though I believe blue is oil. It's like a dark bluish, definately noticable. Though if there's no smoke at all (abnormally) coming out the back you're straight up leaking oil.
Old Sep 21, 2006 | 03:20 PM
screename's Avatar
yeah ill be replacing some gaskets such as the valve cover and oil pan.
is there any way to stop a car from burning oil?
Old Sep 21, 2006 | 03:34 PM
jameskersten1's Avatar
Default Re: (screename)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screename &raquo;</TD></TR><TR><TD CLASS="quote">yeah ill be replacing some gaskets such as the valve cover and oil pan.
is there any way to stop a car from burning oil?</TD></TR></TABLE>
nothing really effective imo other then rebuilding the motor
Old Sep 21, 2006 | 03:50 PM
Brick Top's Avatar
some thicker oil and maybe an additive might help.
Old Sep 21, 2006 | 03:52 PM
Syndacate's Avatar
Did you actually read what I wrote? From the vibe you're giving off, you're 100% implying that it ISN'T smoking. If it isn't smoking and you're using oil like that, you're either A) Pounding VTEC on every single take off in every single gear, or B) have an oil leak.
Old Sep 21, 2006 | 07:47 PM
screename's Avatar
o ok lol. thanks man. so no smoke equals no burning and only leaks, cool. thanks.
Old Sep 21, 2006 | 07:52 PM
Pooby88's Avatar
If you lost that much oil, you should be seeing stains under your car. Valve cover gasket seems to be the usual culprit. Extremely easy to fix.
ender214
Feb 24, 2008 02:32 AM
John 07
Feb 3, 2007 06:58 AM
97dc2
Aug 3, 2005 09:39 PM
Steve26
Jul 29, 2004 05:09 PM
is3oo
Jun 6, 2004 06:49 AM
