Basemap question
My basemap is setup for a t3/t04e , but the t3/t04e i have is ebay garbage . I have a 42/48 air research t3 sitting in my garage id much rather use , how would it affect everything by going to a smaller turbo ? This is on a 96 LS integra with 450cc injectors .
you shouldn't boost on a basemap anyway so it won't effect anything. tune it or you will most likely break it. your basemap should be used to drive to the tuner and not much else.
what did i just say? it is a BASEMAP no it wont make a difference. either way it will not be very close to what you need. you will be richer with a smaller turbo... but you may still be lean because it is a basemap.
Modified by ndogg at 9:20 AM 9/22/2006
