91 CRX RAdius Rod Bushings--Energy suspension
Old Sep 21, 2006 | 03:56 AM
B16CRXT's Avatar
Default 91 CRX RAdius Rod Bushings--Energy suspension
Where do I get them? AUtozone cant get them(they carry ES products), O'Riely's cant get them, I cant find them on ebay or by an internet search. ANyone know where to find them? Mine are shot, and I dont want OEM rubber ****.
TIA!
Old Sep 21, 2006 | 04:17 AM
Autoworks's Avatar
Default Re: 91 CRX RAdius Rod Bushings--Energy suspension (B16CRXT)
http://www.summitracing.com
Old Sep 21, 2006 | 04:57 AM
D95si420's Avatar
o'reilly's can get them, I work for one That is also where the poly bushings for my radius rods came from. all they have to do is order it through arrowspeed (performance parts source) and its the Energy suspension part # minus the period in it after the 16. Hope that helps man. I have them and they helped out wheel hop some, I still have a crappy rack end bushing so the real diff wont be noticed till thats fixed and the car is re-aligned
fireant's Avatar
Default Re: 91 CRX RAdius Rod Bushings--Energy suspension (Autoworks)
That's wierd, I ordered mine at autozone. They can order all ES products and they dont charge you for shipping.
Old Sep 21, 2006 | 04:30 PM
B16CRXT's Avatar
Default Re: 91 CRX RAdius Rod Bushings--Energy suspension (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">That's wierd, I ordered mine at autozone. They can order all ES products and they dont charge you for shipping.</TD></TR></TABLE>
yea, thats why I went there first. Do you happen to have the part number for it and I'll get them to look it up? Thanks!
Old Sep 22, 2006 | 04:14 PM
B16CRXT's Avatar
Default Re: (D95si420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D95si420 &raquo;</TD></TR><TR><TD CLASS="quote">o'reilly's can get them, I work for one That is also where the poly bushings for my radius rods came from. all they have to do is order it through arrowspeed (performance parts source) and its the Energy suspension part # minus the period in it after the 16. Hope that helps man. I have them and they helped out wheel hop some, I still have a crappy rack end bushing so the real diff wont be noticed till thats fixed and the car is re-aligned</TD></TR></TABLE>
The O'reilly's I went to said they cant get ES, but they have some other brand called Goop or something like that. They couldnt find it in that brand either. Does anyone have the PN for either autozone or o'reilly's? I prefer autozone since they can get the ES.
Old Sep 22, 2006 | 06:35 PM
Gtracer15's Avatar
Default Re: (B16CRXT)
Is anyone familiar with the advantages of spherical radius rod bearings as replacements for the OEM rubber and Poly bushings??
Old Sep 25, 2006 | 09:27 AM
B16CRXT's Avatar
Default Re: (Gtracer15)
Bump, does anyone have that PN?
Old Sep 25, 2006 | 09:34 AM
B16CRXT's Avatar
If no one has it, I'll just order it from summit, but I'd like to not have to pay for shipping.
Old Sep 25, 2006 | 09:46 AM
fireant's Avatar
Here you go:
Front Strut Rod Bushing Set - 16.7102
from here:
http://energysuspension.com/pages/hon1.html
Old Sep 25, 2006 | 09:54 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">If no one has it, I'll just order it from summit, but I'd like to not have to pay for shipping.</TD></TR></TABLE>
Summit doesn't charge shipping.
Old Sep 25, 2006 | 10:21 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gtracer15 &raquo;</TD></TR><TR><TD CLASS="quote">Is anyone familiar with the advantages of spherical radius rod bearings as replacements for the OEM rubber and Poly bushings??</TD></TR></TABLE>
first of all, i found no difference between old rubber vs poly bushings in this specific location. it supposedly controlling wheel hop made absolutely no difference, as ive heard before i tried.
as for spherical bearing replacement, it helps with controlling caster when HARD braking, as the momentum of the car pushes the bushing in, but a spherical will not have that flex. but really, its only applicable for track racers.
Old Sep 25, 2006 | 10:36 AM
fireant's Avatar
Default Re: (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Here you go:
from here:
http://energysuspension.com/pages/hon1.html</TD></TR></TABLE>
Darnit, I cant remember if you order two kits or one... but I think it was just one.
Old Sep 25, 2006 | 10:38 AM
Tyson's Avatar
from here:
that is the radius rod bushing.
Old Sep 25, 2006 | 11:47 AM
NastyHabitzCRX's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
helped on my CRX, but as I kept making more power it was harder to control more and more. now with 220+ whp i am looking into traction bars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">Summit doesn't charge shipping.</TD></TR></TABLE>
no but they charge a 'handling fee' which about the same as charging shipping on an item that small. it only works out better when you combine your order to include a lot of stuff at one time.
Old Sep 25, 2006 | 11:49 AM
CRXBart's Avatar
Default Re: (NastyHabitzCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX &raquo;</TD></TR><TR><TD CLASS="quote">
no but they charge a 'handling fee' which about the same as charging shipping on an item that small. it only works out better when you combine your order to include a lot of stuff at one time. </TD></TR></TABLE>
OR just drive there for both Summit, and Jegs are an hour from my house. LOL! IMHO I would buy a traction bar setup. I have the Z-10 kit, and I love it. But I'm guessing if you don't have the cash for shipping you don't have $500 for a new crossmember.
Old Sep 25, 2006 | 04:38 PM
B16CRXT's Avatar
Default Re: (CRXBart)
I've got money for shipping, but why pay shipping when I can get it locally with no shipping cost? ya know? Plus, This isnt gonna be my power house anymore. My plans for this car have done a complete 180. Going to do a mildly built ls/vtec. Hoping to get over 200whp instead of the fully built ls/vtec turbo setup I was planning. It even has A/C now. I want this crx to be a fun daily driver. I'm prolly gonna do a complete resto on it one day. I made 205whp with my old turbo b16 in it at 7 psi and it was very fun. I cant wait to get around that on the motor.
I've got other plans for big power...
I looked on summit racing and saw that they named it the strut rod bushing, so I went back to autozone and told them I needed that for my car, and paid $13 for a set Should be here wednesday.
For suture reference, it is called the Strut Rod Bushing set. And it CAN be ordered from Autozone. Funny thing is, the ES was only like $3 more than factory replacement rubber.
definitely worth it imo.
Old Sep 25, 2006 | 04:45 PM
CRXBart's Avatar
With your plans I would definitly go with a traction bar setup.
Old Sep 25, 2006 | 04:50 PM
B16CRXT's Avatar
I've thought about it and thought about it, but It wont be a dragracer anymore. I prolly wont even take it to a road track. So, I really wont have much use for the traction bars, plus, I have been successful at making everything work around that stock crossmember so far.
Old Sep 25, 2006 | 04:59 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">I've thought about it and thought about it, but It wont be a dragracer anymore. I prolly wont even take it to a road track. So, I really wont have much use for the traction bars, plus, I have been successful at making everything work around that stock crossmember so far. </TD></TR></TABLE>
I don't drag either but with that kind of power it is gonna wheelhop like mad. I love my Z-10 kit. It never even thinks about hoping. I quickly rembered how bad hap was the other day ridding in my friend's 400whp 300ft. lbs. 99 Si. it wheel hops like crazy. I racesd him once when he was untunned, and I had a b16, and I won cause he was hopping so bad. Traction bars are worth every cent.
Old Sep 25, 2006 | 05:03 PM
.Grimace's Avatar
footwork mastery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote"> Where do I get them? AUtozone cant get them(they carry ES products), O'Riely's cant get them, I cant find them on ebay or by an internet search. ANyone know where to find them? Mine are shot, and I dont want OEM rubber ****.
TIA!</TD></TR></TABLE>
did anyone else notice this?
Old Sep 25, 2006 | 05:23 PM
B16CRXT's Avatar
Default Re: 91 CRX RAdius Rod Bushings--Energy suspension (Gremice)
lol, that was saying that Autonzone carries ES products, but they told me they couldnt get that specific one. I apparently was talking to a dumbass that day...
Old Sep 25, 2006 | 05:31 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">lol, that was saying that Autonzone carries ES products, but they told me they couldnt get that specific one. I apparently was talking to a dumbass that day...</TD></TR></TABLE>
They are all dumbasses at my parts store.
sepheroth
May 19, 2015 10:09 PM
Chimichanga
Mar 18, 2009 07:51 PM
mrvrsick
Jun 29, 2008 02:03 PM
civicnooobie
Suspension & Brakes
Jul 7, 2006 09:30 AM
Leo95SE
Feb 5, 2002 03:42 PM
