CEL on the DC5 ITR a!!!
Old Sep 21, 2006 | 01:32 AM
camlob's Avatar
Default CEL on the DC5 ITR after tuning with k-pro!!!
After tuning with the hondata k pro, I've noticed a CEL. After checking it further in the laptop, the code indicated it was coming from the fuel tank sensor. Is there a sensor there? I had an electrician check it and he just saw the fuel pump which was ok. On the stock ecu, the CEL did not appear. There is another thing also, we've noticed at times the temp gauge and ac compressor goes off at the same time. I noticed that in the hondata program, you can enable the ac and the temp gauge together. It cant be the hondata ecu because this problem was occuring with the stock ecu. The CEL only appeared with the hondata ecu.
Any feedback would be greatly appreciated. I was thinking of sourcing a wiring harness from Japan. But it could be overkill and the solution could be minor.
Help....Help.....
EdSales
Mar 4, 2010 10:09 PM
SwappedTURBOegg
Aug 27, 2005 04:34 PM
VisualAutoMotoring
Jul 28, 2003 10:47 AM
ElectronMan
Jun 9, 2003 07:48 AM
